Faulty Cisco 2950 switch
jawad.sharaf
Hello Everyone,
Need Help.. I have a faulty cisco catalyst  2950 for my companys LAN. When turned ON all the 24 ports in switch flashes orange coutinusuly non stop. I can telnet into it via Hyperterminal only.
How can i fix it so it can be used again. If need more information let me know.
Suresh Babu
Please post show log output if any log are being generated.. Based on that it can be addressed
Rgds
Suresh
Switch#sh log
Syslog logging: enabled (0 messages dropped, 2 messages rate-limited, 0 flushes,
0 overruns)
    Console logging: level debugging, 5 messages logged
    Monitor logging: level debugging, 0 messages logged
    Buffer logging: level debugging, 7 messages logged
    Exception Logging: size (4096 bytes)
    File logging: disabled
    Trap logging: level informational, 17 message lines logged
Log Buffer (4096 bytes):
00:00:09: %PLATFORM_HW-3-PCI_FIND_FAILURE:
The number of asics expected were 1, PCI bus scan found -1
00:00:09: %LINK-4-NOMAC: A random default MAC address of 0000.0c89.eb80 has
  been chosen.  Ensure that this address is unique, or specify MAC
  addresses for commands (such as 'novell routing') that allow the
  use of this address as a default.
00:00:09: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
00:00:10: %SW_VLAN-4-IFS_FAILURE: VLAN manager encountered file operation error:
call = ifs_read_until (header) / file =  / code = 21 (Is a directory) / bytes t
ransfered = -1
-Traceback= 8038E104 8038AD94
00:00:10: %SYS-5-CONFIG_I: Configured from memory by console
00:00:10: %SYS-5-RESTART: System restarted --
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(22)EA12, RELEASE SOFTWARE
(fc1)
Copyright (c) 1986-2008 by cisco Systems, Inc.
Compiled Mon 07-Jul-08 23:39 by amvarma
00:00:10: %SNMP-5-COLDSTART: SNMP agent on host Switch is undergoing a cold star
t
Switch#
Contact Cisco TAC.  You need to get this appliance RMA-ed.  There's nothing else you can do to fix this.
