robertkwild
Participant
fex switches bounce to other nexus
hi all,
got two nexus 7000 connected via vpc to eachother but only one switch (core 1) contains all the configs for the 10 fex switches we have attached to them, all the fex switches have port channels to each switch
when they bounce to the other switch (core 2), they lose connection as the configs for them on core 1, so i have to bounce them back to core 1, i do this via doing on core 2
conf t
int po(whatever)
shut
then it goes back to core 1
is there any reason why it bounces them and whats the best remedy for this not happening again
thanks,
rob
1 ACCEPTED SOLUTION
6 REPLIES 6
MHM Cisco World
Advisor
Host VPC (Single Link) and FEX Single Homed (Static Pinning Mode) Straight Through Design
Host VPC (Single Link) and FEX Single Homed (Port Channel Mode) Straight Through Design
whats the difference between static pinned and port channel, as i have said each fex is linked back to core 1 and core 2 via pos on both nexus's plus the nexus's are connected to eachother via vpc
actually we got this
Single Homed Host and Active-Active FEX (VPC) Design
and our nexus versions on each are 12.x
so do our nexus 7ks support this or not
can you draw topology ?
Just looked on both cores and there running v6.2 so this is why it's not working
Thanks so much MHM
