Fiber connectivity
adamgibs7
Level 6
Level 6
Dears,
I m proposing a WS-C3850-12XS-S switch for which I have below question
  1. on WS-C3850-12XS-S sfp+ slot if I insert 1GIG glc-sx-mmd will it work with other 1 GIG SFP glc-sx-mmd
  2. firewall will connect on this model WS-C3850-12XS-S with sfp-10G-SR on port 1 and from port 2 with
    SFP-10G-ZR Itwill connect to Head quarter which is 60KM from the DR. this connection will work if I m not wrong becz don't need to have the complete path as single mode.
  3. If I insert 10GIG SFP+ sfp-10G-SR and reduce the speed by command to 1GIG will it work with other GLC-SX-MMD transceiver
Hello
Looking at your diagram, your fiber connections look compatible
Kind Regards
Paul
6 Replies 6
post a schematic drawing indicating what is connected to what. Also, what firewall, ASA, Palo Alto ?
You can check SFP compatibility here :
https://tmgmatrix.cisco.com/home
>>>>>>>>>>>>>>>>>YES will work
2. firewall will connect on this model WS-C3850-12XS-S with sfp-10G-SR on port 1 and from port 2 with SFP-10G-ZR Itwill connect to Head quarter which is 60KM from the DR. this connection will work if I m not wrong becz don't need to have the complete path as single mode.
>>>>>>>>>>>>>>>>>>>The SFP's sfp-10G-SR and SFP-10G-ZR are compatible with WS-C3850-12XS-S. However exact connectivity can be confirmed if you can share a schematic network diagram as requested by Georg
>>>>>>>>>>NO, this will not work
Hello
@adamgibs7 wrote:
Dears,
  1. on WS-C3850-12XS-S sfp+ slot if I insert 1GIG glc-sx-mmd will it work with other 1 GIG SFP glc-sx-mmd  - YES
  1. firewall will connect on this model WS-C3850-12XS-S with sfp-10G-SR on port 1 and from port 2
    SFP-10G-ZR Itwill connect to Head quarter which is 60KM from the DR. this connection will work if I m not wrong becz don't need to have the complete path as single mode.-these support smf upto 80km,however they are not compatible with mmf 10g-SR if thats what your querying
  1. If I insert 10GIG SFP+ sfp-10G-SR and reduce the speed by command to 1GIG will it work with other GLC-SX-MMD transceiver - As far as i an aware they will not be compatible
check here -
Kind Regards
Paul
Dears,
Attached is the topology,
I will rephrase my question,
from firewall to switch I will use Multi Mode transceivers and from switch another port I will use Single Mode transceivers to reach to HO, as per the diagram.
Hello
Kind Regards
Paul
Leo Laohoo
I'd rather go with a C9500-16X.
