Community Helping Community
411
Beginner
Fibre transceiver compatibility between SF302-8 and catalyst 2960S
    Hi Guys
I want to connect a Cisco small business switch (sf302-8) to a Cisco catalyst 2960S over a mutimode fibre. The transceiver I am using in the catalyst is a GLC-SX-MM. I presume in the SF302, I will have to use a MGBSX1. My question is "are these transceiver compatible with each other and if not, is there a transceiver that will suit both pieces of hardware?"
thanks in advance
2 REPLIES 2
There are no transcievers compatible with both platforms:
table 4 http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps10898/data_sheet_c78-610061.html
table 2 http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/prod_qas0900aecd80322c37.html
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards, Ivan Shirshin **Please grade this post if you find it useful.
Beginner
Thanks Ivan
Content for Community-Ad
