filter monitor session did not work on Nexus5K
aqrxz
hi all,
i have Nexus5548 running NX-OS release 7.1.0.N1.1a
setting in a lab connecting to 2 VM and span the port to VM#2
i tried ping and generate the UDP packet from VM#2 >>> VM#1
but seems the packet capture showing everyting (ICMP,UDP,etc...) like the switch does not filter the packets.
i also tried this on the other switch N5672 running the same version, the result is just the same...
does anyone know how can i able to filter the packet from Nexus?
configuration for monitor session and ACL config as below;
monitor session 1
  source interface Ethernet1/5 both
  destination interface Ethernet1/32
  filter access-group acl-test
  no shut
IPV4 ACL acl-test
        1 permit icmp any any log
        10 deny udp any any log
        20 deny ip any any log
Your ACL filter is not working at all, it seems. Do you have PBR (policy based routing) enabled on the same device by any chance ? There is a bug that says both won't work together...
no pbr enabled on the nexus
can you please tell me more why the ACL won't working?
try and eliminate the 'log' keyword from your access list. I am not sure if logging and capturing go together. So your access list should look like this:
IPV4 ACL acl-test
 10 deny udp any any
 20 deny ip any any
Also, have a look at this document, maybe you find something in there:
http://www.cisco.com/c/en/us/support/docs/switches/nexus-7000-series-switches/116044-nexus-7000-acl-capture-00.html
already removed logging from ACL, but it still the same...
IPV4 ACL acl-test
        10 permit icmp any any
        20 permit udp any any eq 6999
        30 deny udp any any
        40 deny ip any any
ps. from your provided document, i already read it but it's on N7K, so there's no type 'acl-capture' to use.
