First Time planing a network
Andreas.Lechner
i have to plan an realize a network for a school.
they have ~ 180 Ports,  1 Serverroom and 2 Rooms for Switches.
In the serverroom should be a siwtch which can route between the vlans and the server, gateway, ....
the switches should be over fiber cables connected.
My plan is to choose a 3560X 24 Ports Switch as "Core" Switch which routes between the vlans and user 5x Small Business 300 Series 48 Ports Switch for the Clients.
Do you think its a good idea? Does this combination work ?
sorry for my bad english
best regards
Andreas
Edison Ortiz
For a Core, you should go with redundancy and implement a Chassis model or a stacked model.
With the stacked model and Layer3 the solution is 3750-E.
With this design you can also uplink your access switches at 10Gbps.
At the access, I recommend going with 2960s instead of SB300s.
Edison
