FM Errors
Diana Karolina Rojas
Hello community,
I have a problem with a 7600 router, today It had a High CPU process output, I have this logs from the event:
Mar 27 11:45:38 AR: %FM-2-FLOWMASK_CONFLICT: Features configured on interface Port-channel1 have conflicting flowmask requirements, traffic may be switched in software
Mar 27 11:45:39 AR: %FM_EARL7-4-FLOW_FEAT_FLOWMASK_REQ_FAIL: Flowmask request for the flow based feature NAT for protocol IPv4 is unsuccessful, hardware acceleration may be disabled for the feature
Mar 27 11:45:39 AR: %FM_EARL7-4-FLOW_FEAT_FLOWMASK_REQ_FAIL: Flowmask request for the flow based feature WCCP for protocol IPv4 is unsuccessful, hardware acceleration may be disabled for the feature
It was working fine until today and we did not change the configuration. We have WCCP and NAT configurations inside the interface portchannel1:
description ## Conexion a MG_CORE ##
ip address 10.255.252.58 255.255.255.252
ip nat inside
ip wccp 61 redirect in
ip wccp 62 redirect out
mls qos trust dscp
service-policy input Ingreso
The router reached 100% of CPU utilization.
9 Replies 9
Reza Sharifi
Not sure what version you are running but there is a bug associated with this error message.
Have a look at this link:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCth15109/?rfs=iqvred
Hello Reza!
Thanks for the quick reply, the platform where I have the trouble is a 7600 Router with this ios: c7600s3223-adventerprisek9-mz.122-33.SRE12.bin I've been searching for information but I couldn't find any workaround for this problem and I am not sure why is happen.
Hi Diana,
Have you already submitted a ticket with the TAC?
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hello Julio!
Unfortunately this equipment is no longer supported by Cisco, I am trying to help a client.
Regards :)
Hi Diana,
Thank you for the clarification, have you verified if you can upgrade the IOS with any of the fixed images or later?
15.1(2)SY4
15.1(2)SY3
15.1(2)SY2
15.1(2)SY1
15.1(2)SY
15.1(1)SY4
15.1(1)SY3
15.1(1)SY2
15.1(1)SY1
15.1(1)SY
12.2(33.4.22)SXI
12.2(33)SXJ8
12.2(33)SXJ7
12.2(33)SXJ6
12.2(33)SXJ5
12.2(33)SXJ4
12.2(33)SXJ3
12.2(33)SXJ2
12.2(33)SXJ
12.2(33)SXI8a
12.2(33)SXI6
12.2(33)SXI5
12.2(33)SXI14
12.2(33)SXI13
12.2(33)SXI12
12.2(33)SXI11
12.2(33)SXI10
12.2(32.8.11)SX385
Thank you Diana, good luck with the migration!
Hi Diana,
Without any SmartNet contract, it is not easy to upgrade. The IOS (122-33.SRE12.bin) your customer is running is at least 10 years old. It is time to upgrade.
@Julio E. Moisa @Reza Sharifi
We have planned a migration with the customer for the next week, thank both for your time.
Glad to help Diana
Good Luck!
