FNF in 4500E
Roland0Ruiz
Hi All,
Someone knows if the Supervisor 7 L-E included the Application Visibillity (Flexible Netflow FNF) or i must to purchase some license?
Thanks!!
Rolando
cralvara
Level 6
Level 6
Hello Rolando,
The Cisco Catalyst 4500E Supervisor Engine 7L-E includes the  Application visibility through Flexible Netflow . The Cisco Catalyst 4500E Supervisor Engine 7L-E provides 128,000 Flexible NetFlow entries. Based on a custom-built application-specific integrated circuit (ASIC), Cisco Catalyst 4500E Supervisor Engine 7L-E delivers unprecedented flexibility and comprehensive flow visibility extending from Layer 2 (MAC and VLAN) to Layer 4 (TCP, UDP flags, and so on).
For instance, it is not necessary to buy a license.
I hope this information helps you.
Supported links:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps4324/data_sheet_c78-686325.html
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps4324/miercom_report_cisco_catalyst_4500e_se.pdf
Best Regards.
Cristina Alvarado
Cisco Virtual Engineering – Partner Help
Hello Cristina,
Ok, thanks for your answer and the info,
Regards!
Rolando
De: Cristina Alvarado
Enviado el: miércoles, 17 de julio de 2013 08:34 a.m.
Para: Rolando Ruiz Leija
Asunto: - Re: FNF in 4500E
Cisco Communities <https://communities.cisco.com/index.jspa>
Re: FNF in 4500E
created by Cristina Alvarado <https://communities.cisco.com/people/cralvara> in Technology > Borderless Networks
View the full discussion <https://communities.cisco.com/message/128455#128455>
