Forwarding Traffic
kr_madan
Is there any commands to forward the traffic comming from one interface to the other ?
The switch I am using is a Layer-2 4506 device..and I can not enable the routeing...
Thanks in advance.
Jon Marshall
You can use SPAN which can send the traffic received on a source port to a destination port. In effect the traffic is mirrored to the destination port. Be aware though that the traffic from the source port still goes to it's original destination as well. This may or may not be what you want.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/37sg/configuration/guides/span.html
Jon
If I can not enable the routing what are the other options I have to forward the packets ?
Thanks in advance
Madan
