ftp-firewall
ttkmm
Community Member
I have a router that I would like to config as a "ftp-firewall" That means I want to allow just ftp-trafic to-and-from a network to a ftp-server(10.1.1.5).
What would that config look like?
I have maybe done something wrong bacause when I take a "dir" or try to download a file from the ftp-server, it all hangs...
mrmozaffari
Level 5
Level 5
You have to define the access list and bind it to proper interface, like this .
Internet---- (ser0)[Router](fast0)--- ftp server
now we define the access list it should be extended access list :
conf t
access-list 100 permit tcp any host 10.1.1.5 eq ftp
access-list 100 permit tcp host 10.1.1.5 any eq ftp
access-list 100 deny ip any any
now we bind it to serial interface inbound.
interface s0
ip access-group 100 in
thats all
Best Regards Bahman Mozaffari.
m.sir
Level 11
Level 11
FTP can either be in passive or active mode. You configure a router differently depending on which mode you are using.
In active mode FTP server initiate data connection
In passive mode FTP the client initiates both connections to the server
Good explination of active & Passive
http://slacksite.com/other/ftp.html
If you are using FTP in passive mode ACL should be following
from CLIENT side
access-list 101 permit tcp any gt 1023 host 10.1.1.5 eq 21
access-list 101 deny ip any any
from SERVER side
access-list 102 permit tcp host 10.1.1.5 eq 21 any gt 1023
access-list 102 permit tcp host 10.1.1.5 gt 1023 any gt 1023
access-list 102 deny ip any any
m.
