Fuji 16.9.x on 9300 - Flex connect APs
euucsupport
Hi all
Need some help around the port-security on
Topology:
Wireless client > AP (flexconnect) > 9300 switch port > Core switch
My goal here is to enable port-security on the AP Native vlan.
I don't want to enable port-security on rest of the client vlans.
Port will be trunk port with AP vlan as native.
I have followed this url (as below), however it does not show how to enable port-security on just 1 vlan. Reason i say that, as i don't want wireless client affected or bound with the port-security, as wireless clients could be moving from one AP to another.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9500/software/release/16-9/configuration_guide/sec/b_169_sec_9500_cg/b_169_sec_9500_cg_chapter_0101001.html
I believe in the previous version i.e. 12.2, there was option to specify the (as below) to enabled port security on just specific vlans but can't find similar in the latest version.
Switch(config-if)# vlan-range range
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/12-2/25sg/configuration/guide/conf/port_sec.html#wp1061883
Thank you.
MK
pieterh
you can configure port security for specified vlans (vlan-list):
   switchport port-security [maximum value [vlan {vlan-list | {access | voice}}]]
pieterh
Thank you.
