function of stp
ilnaiduccna
hi all
can anebody explain what is the stp & what it's function in vlan
thanks in advance
ankbhasi
Hi Friend,
There are number of documents available and I will recommend you to read the docs and incase you have any doubts please come back with the same.
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/sw_ntman/cwsimain/cwsi2/cwsiug2/vlan2/stpapp.htm
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_13_ea1/configuration/guide/swstp.html
Ankur
