Function of Switch
ssweehin
Apart from doing trunking, vlan, share the network, what is the other functions of cisco switch? Can it be used for routing? Please show the example. Thanks.
mahmoodmkl
Level 7
Level 7
If it is a multilayer switch it can be used for routing.eg.intervlan routing in u r switch,
Mahmood
cisco_lad2004
Level 5
Level 5
switches can also seen as a good way to provide access port density. so end customers are, for examples linked up at 100Mb, then trunked to upper layers on a single high speed port or even more as ether-channel.
Sam
My friend, I recommend you buy a CCNA/Introduction to Cisco Networking book and read it.
All your questions will be answered there.
Victor
