FW[MOD 33]: radian_monitor_pll:: port_num[12] unit[3] bcmport[5] : PLL reset failed - xlport_xgxs_status_gen_reg = 0x0 xlport_xgxs_ctrl_reg = 0xFF800
Hello Everyone,
Here is my C6832-X-LE VSS switch log , I could not find anything related or any lead to this log and need help to reach the problem, I appreciate if you share your comment for this problem and on the other hand the port do not operate on both switches randomly so i could not lead to a conclusion for this problem as well.
Iliya Gatsev
My name is Iliya Gatsev from Cisco Technical Support Team.
The Catalyst series are not considered Small Business devices so I can suggest to post your question in the Network Infrastructure section to get to resolution quicker.
Please rate this post or marked as answered to help other Cisco customers.
Iliya Gatsev
Cisco STAC Network Engineer
Together we are the human network .:|:.:|:. CISCO
Leo Laohoo
No one has seen this error message before. I'd recommend you raise a TAC Case.
jonathanpumida1
I have the same issue with C6880-X-LE running VSS on version 151-2.SY10. Already opened a TAC case for this and the findings is that we are hitting an internal bug, details are still sketchy as there are little information that they can share but current workaround is to reboot the whole VSS and verify while their recommendation is to upgrade to latest recommended version.
