garbled output
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
01-31-2006 03:19 PM - edited 03-05-2019 11:46 AM
Hi Folks,
I have a 7300 router, running 12.2.27sbc1
the only problem I have is output of the show config, it is garbled,
the show run, show start, are ok,
and it is garbled at the same portion of the config always,
there is no problem with my session, it is an OC3,
I will include an example of the garbled output:
Retried the sh conf - it fails again
ehbgrt8#sh conf | inc 10.175.0.0
access-list 103 permit ip 10.175.0.0 0.0.255.255 any
Note the garbled route
ip route 10.175.ip route 12.38.144.128 255.255.255.192 172.21.128.2
strange huh ?
I tried to writet mem, and it works, but the problem is still there,
I researched the bug toolkit for this one, and did not see, or maybe I did not cover all the possible keywords in my search,
any help, or if you know a bug id, I would appreciate it.
thanks
- Labels:
LAN Switching
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-02-2006 07:44 AM
from where are you executing the command (show config), from a VTY (Telnet) session, or from a console session ? The problem might be with your emulator software, which one do you use (Hyperterminal, TeraTerm) ?
Nethelper
