Join Customer Connection to register!
748
Sean Gilkes
Beginner
Gathering QoS Statistics from Nexus 7000 with SNMP
Hi all,
     We would like to gather queue packet drop information from interfaces which is viewable using this show command:
sho policy-map interface port-channel 3 type queuing
Global statistics status :   enabled
port-channel3
  Service-policy (queuing) input:   default-in-policy
    policy statistics status:   enabled
    Class-map (queuing):   in-q1 (match-any)
      queue-limit percent 50
      bandwidth percent 80
      queue dropped pkts : 0
    Class-map (queuing):   in-q-default (match-any)
      bandwidth percent 20
      queue dropped pkts : 1708412     <---- these values
I have tried using the Cisco-Port-QoS-MIB but when I perform a walk I get the error "no instance".  Is there a different MIB that should be used..?
Sean
0 REPLIES 0
