Switching
Get 20% off switches when you combine Cisco solutions
Labels
Hi, Do you have been happen this logging show that, and there are none any effect to our netwoek bunisness. im client 'chasfs' has taken 332 msec (runtime: 332 msec) to process a 'stack chasfs fd' messageMar 28 23:25:32.568: %IOSXE_INFRA-6-PROCPATH_C...
hansons by Level 1
  • 42 Views
  • 1 replies
Hello, I can't manage to give the connected PCs an ip through the dhcp server. My packet tracer + network design are attached. Have currently only started on the bottom part so it's only about the bottom PCs.Thanks in advance for the effort
TS40 by Level 1
  • 115 Views
  • 1 replies
I am trying to configure a trunk port on a Cisco 3750 that has fiber running to a ruckus 7150 switch.My current config connects the switches but it is only passing vlan1 traffic and I want multiple vlans. Therefore, I configured the port as a trunk o...
oowJ by Level 1
  • 172 Views
  • 4 replies
Hello everyone!I'm not a network engineer but as a subsystem (kernel + filesystem) engineer I know the network concept.Few months ago, I designed a DMZ and configured my 2 node VPC with 6 rack switch.Everything was smoothly working but I started to s...
Ozy by Level 1
  • 106 Views
  • 1 replies
On Nexus 7000s I want to limit bandwidth of particular IP. I can do this using proper configuratio of IP ACL, policy map and class map. But what if I dont have information on interface?  Can I apply bandwidth control for particular IP without knowing...
liveshell by Level 1
  • 952 Views
  • 5 replies
I have a less then a dozen Cisco 3850 switches that I am working on.  I need to configure 802.1x authentication.  The issue is the switches are reaching out to Cisco ACS and I need to set up radius server to enable 802.1x.  The Cisco ACS I found out ...
John N by Level 1
  • 224 Views
  • 6 replies
Am trying to create a new local account on a Nexus 3048 so I can SSH to it if my Radius server doesn't work.  Normally, I log in with my AD account which the switch uses Radius for authentication with that.  However, when I run the command to create ...
mramj499 by Level 1
  • 74 Views
  • 1 replies
Dear community I am getting into NetFlow a little bit deeper but cannot get my head around sampling. All i understand so far: We can configure deterministic sampling, that uses a hardware sampler per interface, limiting the maximum number of monitori...
Hi All , I am in the testing phase of migrating to a 9300. So far I have done the below.3850 running 16.3.6   and 9300 updated 17.09.04aI have copied the start-up config to the 9300 - all looks ok apart from the usual ip routes , some interfaces not ...
machine23 by Level 1
  • 116 Views
  • 2 replies
