Gig blade from 4006 to 4510
paulc
Can I use a 10/100/1000 blade from a 4006 in a 4510?  I would think I could but I wanted to verify.  Also, can I do a hot-swap (the 4510 is live but the 4006 is shut-down)? Thank you.
5 Replies 5
Alan Taylor
Hi Paul,
Having done a quick check through cisco.com it appears the line cards are compatible with both chassis.
http://www.cisco.com/en/US/products/hw/switches/ps663/index.html
Installing the card in the 4500 while it is powered on shouldn't pose any great problems although I would recommend that you make reasonable effort to reduce the potential impact if the switch is affected i.e. schedule the install out of core hours.
Edit : for thoroughness it would probably be a good idea to search on the card product ID and check the datasheet.
Hope that helps,
- Sudo.
Message was edited by: Pseudopath - addtional remark
Thanks, Sudo.  Unfortunately, I picked the wrong slot.  No lights came on when I inserted the card so I checked the 4510 log:
000616: *Sep 23 09:13:14.117: %C4K_CHASSIS-3-LINECARDNOTVALIDINSLOT: Module WS-X
4424-GB-RJ45 is not supported in slot 10, try slots 1, 2, 3, 4, 7, 8, 9.
When I get a sec, I'll try one of the other slots.  I also have another s4506 gbic' card  to place.  Now, I'm wondering if I'll have room for both.  When I got the 4510, one of the techs said that one slot would not work because it was designated for a supervisor card in case we should ever want to add another supe engine for backup\redundancy.
Well, no service interruption is a good thing and the switch survived so another positive! I'm sure the next time will be fine.
Slots 5 and 6 are reserved for the supervisor modules, as per what the tech said.
Regarding the log entry you received; I encountered problems with a 6500 chassis once that didnt like having a module inserted due to the power drain of all the others, maybe ensuring you have enough wattage could help. Looking at the details I could find there doesnt appear to be suggestions/restrictions on the slot you should use for your card I would suggest one closer to the top of the chassis if possible, no evidence to back this up but it seems to me that the power starts at module 1 then 2 etc. but as I said no evidence just my assumptions and what my experience with the 6500s suggest.
Anyway, hope that helps and good luck with the next attempt.
- Sudo.
PS. please consider using the correct answer option if any post resolved your question.
Thanks for the reply.  I successfully added a 10/100/1000 blade from a 4006 into slot 9. I'm going to open a TAC with Cisco (now that I've finally got the contract number for the device) and find out why slot 10 appears to be unavailable.
Hello Paul,
Before opening a tac case, can you specify the type of Sup you are using in the 4510 ?
Is it a SUP V (WS-X4516)  ? Indeed from page  http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps4324/product_data_sheet09186a00801fcaba_ps2797_Products_Data_Sheet.html  Chassis and Line Card Support - Table 1  we can see :
* When the Supervisor Engine V is used in the  Cisco Catalyst 4510R chassis, slot 10 (FlexSlot) will support a subset  of line cards: the 2-port GBIC (WS-X43 02-GB) and Access Gateway Module  (WS-X4604-GWY). Future Supervisor Engines will allow slot 10 to  accommodate any and all line cards.
That could explain why your 4424-GB-RJ45 is not supported in slot 10...
Cheers
Karim
