GLBP configuration
sly007
Kindly assist in troubleshooting GLBP functionality
GLBP has been configured one 2951 and 3945 (using the etherswitch module on 3945) Routers, using OSPF.   After configuration, the load-balancing is working properly, as the route from the local systems periodically changes from Route 1 to the other and back at regular interver. But whenever I shut down a link, to test the functionality and availability of the redundant link of GLBP, the whole  circuit would go down, making destination no longer reachable. I believe there is something that ought to be done or some of the configurations is not complet. Please help troubleshoot, the configs are below.
In addition, how is the "ip sla group"  configured on the 2951 and 3945 Routers, to be able to track objects? It gives me the "ip sla responder" and "ip sla key-chain" options on image version c2951-universalk9-mz.SPA.150-1.M3.bin
ROUTER_1
GigabitEthernet0/0         192.168.215.252 YES NVRAM  up                    up
GigabitEthernet0/1         192.168.155.2   YES NVRAM  up                    up
GigabitEthernet0/2         unassigned      YES NVRAM  administratively down down
GigabitEthernet1/0         unassigned      YES NVRAM  administratively down down
Router_1#sh run int g0/0
interface GigabitEthernet0/0
description Call Center LAN
ip address 192.168.215.252 255.255.254.0
duplex auto
speed auto
glbp 10 ip 192.168.215.254
glbp 10 timers 5 18
glbp 10 priority 101
glbp 10 preempt
glbp 10 weighting 100 lower 91 upper 91
glbp 10 load-balancing weighted
glbp 10 weighting track 1 decrement 10
track 1 interface GigabitEthernet0/1 line-protocol
ROUTER_2
Interface                  IP-Address      OK? Method Status                Protocol
GigabitEthernet0/0         unassigned      YES NVRAM  administratively down down
GigabitEthernet0/1         192.168.155.6   YES NVRAM  up                    up
GigabitEthernet0/2         unassigned      YES NVRAM  down                  down
Serial0/0/0:0              unassigned      YES NVRAM  down                  down
Serial0/0/1:1              unassigned      YES NVRAM  down                  down
GigabitEthernet2/0         192.168.215.253 YES NVRAM  up                    up
Router_2#sh run int g2/0
interface GigabitEthernet2/0
ip address 192.168.215.253 255.255.254.0
ip nbar protocol-discovery
glbp 10 timers 5 18
glbp 10 preempt
Do you get a different result if you physically pull the cable? If you have a specific route that you receive from the other side, you could try changing the tracking config to track the route. For example, if you receive prefix 192.168.1.0/24 from the provider, you could configure track like:
track 1 ip route 192.168.1.0/24 reachability
Otherwise, there are some tracking issues with the IOS version that you're running. You could try to update the IOS to see if this other problem is resolved. Personally, if pulling the cable still doesn't show you that the interface is down (tracked), then I would update the IOS first to see if it worked. I've tested shutting down the interface to see if line protocol was seen as down, and it is:
Track 1
  Interface FastEthernet0/0 line-protocol
  Line protocol is Down (hw admin-down)
    4 changes, last change 00:00:04
Notice that it says admin-down, so you, in theory, should be seeing the same thing. Your glbp configuration should work fine once you get the tracking situation resolved.
HTH,
John
HTH, John *** Please rate all useful posts ***
9 Replies 9
John Blakley
It looks like you're tracking the incorrect interface. You should be tracking g0/0 in order for the decrement to work. On R2, you're tracking the incorrect interface there as well, so you'd want to change it to g2/0.
As far as your other question, the Universal base image doesn't support a full implementation of ip sla. You'd need at least the data license for that functionality. But overall, your tracking command should work.
HTH,
John
Hello John,
Please correct me if i am wrong. I was thinking the uplink/wan interface is the one to track..
The G0/0 interface is the LAN interface, and it is not expected to break down, because that is where the GLBP is configured.
However, could that be the only reason why the local destination would not be reachable when one of the links goes down?
Please reply.
Thank you.
My apologies. So, since you're tracking the wan interface, did you physically pull the cable to simulate an outage? One problem with tracking on an ethernet segment is that if your circuit were to go down, you won't necessarily see your line protocol go down because it's connected into a switch that's still up. This is where the sla comes in. You can ping the other side and then fail over if the other side stops responding.
So, a couple of questions:
1. How are you testing?
2. Can you test again?
3. When it's down, can you post "show glbp"?
John
Thanks for your prompt response.
  1. I test by administratively shutting down the end of the WAN interface
  2. I just tested before i sent the reply, and
  3. below is the output when i just shut down the uplink interface again.
ROUTER_1
GigabitEthernet2/0 - Group 10
  State is Standby
    1 state change, last state change 01:27:50
  Virtual IP address is 192.168.215.254
  Hello time 5 sec, hold time 18 sec
    Next hello sent in 0.928 secs
  Redirect time 600 sec, forwarder timeout 14400 sec
  Preemption enabled, min delay 0 sec
  Active is 192.168.215.252, priority 101 (expires in 17.856 sec)
  Standby is local
  Priority 100 (default)
  Weighting 100 (configured 100), thresholds: lower 91, upper 91
    Track object 1 state Up decrement 10
  Load balancing: weighted
  Group members:
    c84c.7563.8750 (192.168.215.253) local
    f866.f27b.4db0 (192.168.215.252)
  There are 3 forwarders (1 active)
  Forwarder 1
    State is Listen
    MAC address is 0007.b400.0a01 (learnt)
    Owner ID is unknown
    Time to live: 8959.360 sec (maximum 8962 sec)
    Preemption enabled, min delay 30 sec
    Active is 192.168.215.252 (secondary), weighting 100 (expires in 15.936 sec)
  Forwarder 2
    State is Listen
    MAC address is 0007.b400.0a02 (learnt)
    Owner ID is f866.f27b.4db0
    Time to live: 14397.376 sec (maximum 14400 sec)
    Active is 192.168.215.252 (primary), weighting 100 (expires in 18.304 sec)
  Forwarder 3
    State is Active
      1 state change, last state change 01:27:55
    MAC address is 0007.b400.0a03 (default)
    Owner ID is c84c.7563.8750
    Active is local, weighting 100
ROUTER_2
GigabitEthernet0/0 - Group 10
  State is Active
    1 state change, last state change 01:34:45
    Next hello sent in 0.096 secs
  Active is local
  Standby is 192.168.215.253, priority 100 (expires in 17.056 sec)
  Priority 101 (configured)
  Group members:
    f866.f27b.4db0 (192.168.215.252) local
  There are 3 forwarders (2 active)
  Forwarder 1
    State is Active
      1 state change, last state change 01:30:35
    Owner ID is c84c.7563.8718
    Redirection disabled
    Time to live: 8967.168 sec (maximum 14400 sec)
    Client selection count: 68
  Forwarder 2
    State is Active
      1 state change, last state change 01:34:09
    MAC address is 0007.b400.0a02 (default)
    Redirection enabled
    Client selection count: 500
  Forwarder 3
    State is Listen
    MAC address is 0007.b400.0a03 (learnt)
    Redirection enabled, 599.072 sec remaining (maximum 600 sec)
    Time to live: 14399.072 sec (maximum 14400 sec)
    Active is 192.168.215.253 (primary), weighting 100 (expires in 17.504 sec)
    Client selection count: 460
Thank you
Can you also post "show track" while this is down?
please find below the result of "show track" while the line is shut down
Track 1
  Interface GigabitEthernet0/1 line-protocol
  Line protocol is Up
    1 change, last change 00:07:13
  Tracked by:
    GLBP GigabitEthernet2/0 10.
What could be wrong?
Really interesting. So this o/p of 'show track' is when the interface gi0/1 was admin shut'd. You are sure the interface went down. Did you capture a 'show interface gi0/1' / 'show ip int br' just to confirm?
Thanks for your assistance.
The GLBP works quite well, providing Hardware Availability, and Load Balancing, at this I have confirmed this.
But the challenge is when any of the interfaces at the Headquarters is shut down, the whole link goes off. I expected to see a redundancy.
Please see the attached diagram in PDF.
I am thinking the reason while the tracking is "is not effective" is because the interface at the remote site is connected to an active port on the transparent switch. Therefore, I seek to configure "IP SLA object" on the 2951 and 3945 Routers.
Is there any solution on how to "IP SLA object" on Cisco 2951 and Cisco 3945 Routers?
Track 1
HTH,
John
