Global vs interface switch command
Hello, If I have a command globally which applies on all switch ports but then I want to configure one port with a different command not apply the global command on the switch. When i configure that port will it take effect the new command configure for that port and disregard the global command that was apply on the other ports?
Reza Sharifi
What is the command?
Dragan Ilic
Level 4
Level 4
Well without testing and not knowing more details about what command you wish to try - I think that more specific (in this case interface command) will take precedence above global one...
Plese do some testing - in this particular case it's about 5min job...
BR,
Dragan
HTH,
Dragan
