GRE Tunnel Protocol Down - Any help would be Awesome
jasonbutryn
See the attached:
Cant figure out why the tunnel had a 'down' protocol.
If you need more info from the routers...Let me know.  Thanx Team.
38 Replies 38
Great!
About the point to point subnets is the network that you used to connect to routers for example: 10.13.2.0/30
Do you see the source and destination on Fox13 and 14?
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Do the source and destination subnet masks need to match the tunnel subnet mask?
The source and destinations used on the topology are related to the subnets of the P2Ps but if you are referring to the tunnel IP, yes they should be the same subnet mask.
Hi Jason,
Checking your config on Fox13, the serial interface with ip 10.13.2.2 is shutdown. It should be enabled.
Sorry its so late.... i do not see it being shutdown:
Serial2/1 is up, line protocol is up
Hardware is M4T
Internet address is 10.13.2.2/30
MTU 1500 bytes, BW 1544 Kbit/sec, DLY 20000 usec,
Encapsulation HDLC, crc 16, loopback not set
Keepalive set (10 sec)
Restart-Delay is 0 secs
Last input 00:00:02, output 00:00:00, output hang never
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1158 kilobits/sec
14168 packets input, 1172976 bytes, 0 no buffer
Received 4569 broadcasts (0 IP multicasts)
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
15195 packets output, 1255474 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
2 carrier transitions DCD=up DSR=up DTR=up RTS=up CTS=up
Hi  my friend,
This is my configuration:
FOX13
vrf definition PIPE
rd 1:1
address-family ipv4
exit-address-family
interface Tunnel0
ip address 10.1.1.1 255.255.255.0
tunnel source 10.13.2.2
tunnel destination 10.4.14.2
tunnel vrf PIPE
interface Serial0/0
vrf forwarding PIPE
ip address 10.13.2.2 255.255.255.252
router ospf 1 vrf PIPE
network 10.13.2.2 0.0.0.0 area 0
ECHO2
vrf definition PIPE
rd 1:1
address-family ipv4
exit-address-family
interface Serial0/0
vrf forwarding PIPE
clock rate 64000
ip address 10.13.2.1 255.255.255.252
interface Serial0/1
vrf forwarding PIPE
clock rate 64000
ip address 10.2.4.2 255.255.255.252
network 10.2.4.2 0.0.0.0 area 0
network 10.13.2.1 0.0.0.0 area 0
ECHO4
vrf definition PIPE
rd 1:1
address-family ipv4
exit-address-family
interface Serial0/0
clock rate 64000
vrf forwarding PIPE
ip address 10.4.14.1 255.255.255.252
interface Serial0/1
vrf forwarding PIPE
ip address 10.2.4.1 255.255.255.252
network 10.2.4.1 0.0.0.0 area 0
network 10.4.14.1 0.0.0.0 area 0
FOX14
vrf definition PIPE
rd 1:1
address-family ipv4
exit-address-family
interface Tunnel0
ip address 10.1.1.2 255.255.255.0
tunnel source 10.4.14.2
tunnel destination 10.13.2.2
tunnel vrf PIPE
interface Serial0/0
vrf forwarding PIPE
ip address 10.4.14.2 255.255.255.252
network 10.4.14.2 0.0.0.0 area 0
FOX13# ping vrf PIPE 10.4.14.2 source 10.13.2.2 repeat 10
Sending 10, 100-byte ICMP Echos to 10.4.14.2, timeout is 2 seconds:
Packet sent with a source address of 10.13.2.2
Success rate is 100 percent (10/10), round-trip min/avg/max = 1/1/2 ms
FOX13#
FOX14# ping vrf PIPE 10.13.2.2 source 10.4.14.2 repeat 10
Sending 10, 100-byte ICMP Echos to 10.13.2.2, timeout is 2 seconds:
Packet sent with a source address of 10.4.14.2
FOX14#
Hope it is useful
HAHA... Maybe not..The tunnel protocol is now up, but the routers still cannot ping each other
No worries my friend, let me lab your config and share it with you.
But the Tunnel11 Protocol is still down.
