05-29-2015 11:13 AM - edited 03-08-2019 12:15 AM
Hello all,
Need advise/help from this community.
Currently there is existing supervisor Sup V-10GE installed on 4507R-E chassis.
I want to add another supervisor Sup-8E to the chassis.
Both supervisor running on different IOS version/type (existing using ios and sup-8e using ios XE).
Is it possible to make HA between them?or do I need manually upgrade older sup ios to ios xe to make HA sync work?
Faris
05-29-2015 11:37 AM
Hi Faris,
To do HA/SSO on the sups, both Sups need to be exactly the same. They also need to be running the same exact version of IOS.
06-02-2015 12:11 AM
Hi Reza,
Thanks for the response.
