Showing results forĀ
Search instead forĀ
Did you mean:Ā
Hardening Document based on specific OS
umeshagroya
I would like know whether there are hardening documents based on specific OS for cisco products for eg. Nexus, IPbase, Lanbase, ADVENTERPRISE. As some of the hardening commands are not supported on all the different versions.
Reza Sharifi
I don't think, there is hardening document per OS, or per feature set or even per platform.  Here is a document you can use for most Cisco devices. Some commands may vary.
http://www.cisco.com/c/en/us/support/docs/ip/access-lists/13608-21.html
Julio E. Moisa
Check this link, it could be useful: http://blogs.cisco.com/security/best-practices-device-hardening-and-recommendations
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
