10-27-2016 12:44 PM - edited 03-08-2019 07:57 AM
Alright so here is the story: 15 year old from canada, bought 2 2948g switchs off craigslist for $20 each, i was wondering if
A. these run catOS or ios? they currently have a 6.1 version of something from 2001... whether its catos or ios im not sure?
B. Is it possible to pass my ccna from learning with these switchs? of course i understand id need a couple of routers too, still on the hunt for those.
C. what is the factory reset instructions for these? they have no mode button..
D. where can i get an updated IOS/ catOS for these since they are EOL already
Side note: these are the original 2948g not the 2948g-ge-tx
EDIT: i tried some ios commands on them... "set ip http server enable" worked... thats an ios command right? im not crazy/stupid?
Solved! Go to Solution.
10-27-2016 01:05 PM
CatOS
B. Is it possible to pass my ccna from learining with these switchs? of course i understand id need a couple of routers too, still on the hunt for those.
Not snowball's chance in h3ll.
10-27-2016 01:05 PM
CatOS
10-27-2016 01:08 PM
as i just added in my edit: i tried some ios commands on them... "set ip http server enable" worked... thats an ios command right? im not crazy/stupid?
10-27-2016 01:14 PM
If the configuration command starts with a "set" instead of "config t", then it's CatOS.
10-27-2016 01:37 PM
oh. i see. feel stupid now... thank you anyway. is there a solved button on these forums?
10-27-2016 02:10 PM
You can still sell them if the switch works.
There should be an "Answered" button.
10-27-2016 02:12 PM
alright. thx.
