Help! 2851 Spitting out Symbols
Palmeto422
I am a networking student and was playing around with a  Cisco 2800 series router. Couldnt figure out the pwd or user name so was  following these steps from this KB
http://www.cisco.com/en/US/products/hw/routers/ps259/products_password_recovery09186a0080094675.shtml#ex_pass
for  PWD and User Reset..... Although by the time I got to selecting a  username and pwd the computer had went to sleep so I  started over  again.
When  I restarting this process I ejected the Flash memory told it to reset  but failed to reinsert the flash card before it rebooting....
now in the terminal I get symbols instead of words. What can I do ?
Thanks for taking the time to read this - Will
attached  is a photo of the issue
Reza Sharifi
Hi Will,
You may have a mismatch baud rate between the router and the emulator you are using.  Try changing the baud rate on the MS emulator to 9600 and try again.  First click on disconnect, then go to the property of the com port you are using then change the baud rate.  Start with 9600 if that does not work for you try the other numbers like 38400
