Help choosing switch
lres
Community Member
Could someone please help me spec a switch with the following features?
- Protocols: TCP/IP, EtherNet/IP, DHCP, BOOTP , IGMP, SMTP, STP, RSTP,MSTP, PVST+, VTP, SNMP, NTP
- 48 ports (2 multimode Gb fiber ports)
- 36 devices need 10/100 speed (RJ45 connectors).
- Rack mount design.
- IP rating: this is not important. The switch will be stored in an appropriate/safe enclosure.
- No Poe ports.
Scenario: 3 industrial production lines. 12 devices per line. They are all in the same subnet/VLAN.
Network is isolated from the business network.
Would you recommend using a few smaller switches instead of 1 larger switch? Why?
Thank you in advance!
balaji.bandi
First need to make small diagram, how you looking to deply where you going to deploy (if you are not sure i suggest contact Local partner they can help you also make you BoM for you) - still you like to DIY
here is the information :
For Industrial Switches : ( these are design to work on idustrail area)
https://www.cisco.com/c/en/us/products/switches/industrial-ethernet-switches/index.html#~stickynav=2
For Office network or Campus lan ( Cat 9200 and Cat 9300 is good)
https://www.cisco.com/c/en_uk/solutions/enterprise-networks/catalyst-9000.html#~overview
Cat 1000 also part of this deal.
you want to save cost you can Look Cat 29XX  seriest also.
If you looking Small end switches  SG
https://www.cisco.com/c/en_sg/solutions/small-business/switches.html
Depends on requirement, if you put all eggs in basket risk is high, compare to spreading eggs in to different basket.
BB
Leo Laohoo
- No Poe ports
What is budget?
This can be done with a Catalyst 1000.
