06-26-2014 12:57 AM - last edited on 03-25-2019 04:29 PM by ciscomoderator
Hello master,
I want to upgrade IOS on my switch but i erase the IOS in flash first.
no i cannot copy IOS to my switch
I have read Xmodem protocol to send the file to switch, should i do that?
Solved! Go to Solution.
06-26-2014 02:14 AM
Hi Dani.
Yeah you can do with the xmodem option to load the IOS. But it will take more time...
rommon1> xmodem -cfs115200 <IOS Name.bin>
or
rommon1> xmodem -c <IOS Name.bin>
then configure your hyper terminal
once download completes
rommon 9 >dir flash:
it will show the uploaded IOS.
rommon 10 >confreg 0x2102 You must reset or power cycle for new config to take effect. rommon 11 >reset
do this step. You will get the device booted from uploaded IOS.
You can refer the below URL for any clarification.... everything is defined in the document clearly....
http://www.cisco.com/c/en/us/support/docs/routers/2600-series-multiservice-platforms/15085-xmodem-generic.html
Karthik
06-26-2014 02:14 AM
Hi Dani.
or
Karthik
