Help packet tracer
How do I setup DHCP on a multi-layer switc
omz
Configuring DHCP Server on a Router or Layer 3 Switch
Router(config)#ip dhcp pool internal
Creates a DHCP pool called internal.
Router(dhcp-config)#network 172.16.10.0 255.255.255.0
Defines the range of addresses to be leased.
Router(dhcp-config)#default-router 172.16.10.1
Defines the address of the default router for the client.
Router(dhcp-config)#dns-server 172.16.10.10
Defines the address of the Domain Name System (DNS) server for the client.
this is pretty straightforward. Just create a DHCP pool for each (VLAN) interface. A sample file is attached...
ip routing
ip dhcp excluded-address 192.168.1.1
ip dhcp excluded-address 192.168.2.1
ip dhcp excluded-address 192.168.3.1
ip dhcp pool VLAN1
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8
ip dhcp pool VLAN2
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
dns-server 8.8.8.8
ip dhcp pool VLAN3
network 192.168.3.0 255.255.255.0
default-router 192.168.3.1
dns-server 8.8.8.8
interface Vlan1
interface Vlan2
mac-address 0090.21b5.b101
ip address 192.168.2.1 255.255.255.0
interface Vlan3
mac-address 0090.21b5.b102
ip address 192.168.3.1 255.255.255.0
