Help Please Active/Standby ISP Link
fatalXerror
Level 5
Level 5
Hi Guys,
Good Day!
Need help, I have 2 routers which I will be configuring as my edge routers and this routers will be having iBGP in each others and eBGP for ISP links however, I only have 1 ISP with 1 router only meaning my 2 routers will be connecting to the sole ISP router.
I would like to seek help how can I do it so that there will be primary and secondary link towards the ISP router?
nagasheshu2010
Hope you are doing well.
I would like to understand your question little more.
"I only have 1 ISP with 1 router only meaning my 2 routers will be connecting to the sole ISP router." - Means, the EDGE(CPE routers) connects to same ISP and same router?
Sheshu.
5 Replies 5
nagasheshu2010
Sheshu.
fatalXerror
Level 5
Level 5
Hi nagasheshu2010,
Good Day!
You are correct, I have 2 CPE routers which I wanted to connect to only 1 ISP (1 router).
Can you help me please.
Well, you can do the following.
Lets suppose router 1 is primary and router 2 is secondary.
To control outgoing traffic, use "as-path prepend in" feature in router 2.
To control incoming traffic, use MED feature. Apply low MED in router 1 and high in router 2 or you can ask ISP to apply high Local preference for router 1 BGP neighbor and low LP for router 2 BGP neighbor.
Hope this helps.
let me know if you are looking for config template.
Sheshu.
Hi nagasheshu2010,
Good Day!
May I ask why only Router 2 will be configured with "as-path prepend in"?
When two or more routes exist to reach a particular prefix the default in BGP is to prefer the route with the shortest AS Path length.
Lets assume we are receiving "x route" on router 1 and router 2 with same AS path then the decision goes to the next BGP attributes.
IF we apply, "as path prepend in" in router 2 and change the as path of "x route" to something higher in router 2 than the router 1, then it prefers router 1 route.
Hope this explains.
Sheshu.
