help regarding commands
mayankparekh13
Hi all
These is a silly question but pls give the information about ip virtual-reassembly and encapsulation ppp ,why we use that and if not use what happened ? pls...
mahmoodmkl
Level 7
Level 7
Let me try this.
ip virtual-reassembly N/A
encapsulation ppp is used on serial lines or ISDN lines this is L2 encapsulation protocol used to transfer ur IP data over these media.If u r connecting two remote locations over serials links then u have a choice of using either HDLC or PPP.
If u r not using this then the connection will not be established.
Mahmood
thanks mahmood,
give the help about encapsulation ppp
As i said in the above post its L2 encapsulation protocol used on serial lines to transport ur IP data.
Mahmood
