Help with ACL on new bridged config
commandlinekid
Hello. THANK YOU in advance for helping me. -J
Background: My config until yesterday: Old ISP: Traditionally routed /28 to WAN interface, with VLANS on a 1924 attached to my 2621. One VLAN was NAT using one of the /28 IPs as overload, and the other VLAN was the /28 itself for servers.
My config now and what I need help with:
1.) I have a new ISP and new /28 assigned to my bridged connection (ethernet).
2.) Problem is: They won't route me the subnet, but instead they'll hang it off Their  router and make me use the first IP in the subnet as my gateway.
3.) Now: I have this working but I'm having a problem assigning ACL and inspect FOR the 0/1.4 interface (NAT interface seems fine) so my servers have these ACLs assigned like they used to.
My setup in layman's terms as new background:
1.) Same VLAN setup as before. One NATting and one with Public IPs.
2.) I can assign the inspect stuff to the BVI interface BUT....my FE 0/1.4 which has my public IPs on it is WIDE open and the ACL isn't taking on there.
Question: How do I fix?
Here is my config. So again it's all working fine Except......... On FE 0/1.4 where I have my servers (public IPs of the /28), I cannot assign these two things that I need:
ip access-group internet-facing in
ip inspect AllowtoComeBack out
Config (partial):
interface FastEthernet0/0
description DMZ TO ISP
no ip address
no ip mroute-cache
duplex auto
speed auto
ntp disable
no cdp enable
bridge-group 32
interface FastEthernet0/1
description dot1Q trunk to switch 10.1.40.2
no ip address
no ip mroute-cache
duplex auto
speed auto
ntp disable
interface FastEthernet0/1.2
description EMPLOYEE VLAN 2
encapsulation dot1Q 2
ip address 10.1.41.1 255.255.255.0
ip helper-address 10.1.41.3
no ip redirects
ip nat inside
no snmp trap link-status
interface FastEthernet0/1.4
description Internet SERVERS PUBLIC IPS IN THE /28
encapsulation dot1Q 4
no ip redirects
no cdp enable
bridge-group 32
bridge-group 32 spanning-disabled
interface BVI32
ip address 207.81.254.137 255.255.255.240
no ip redirects
ip nat outside
crypto map cm-cryptomap
ip nat pool thenatpool 207.81.254.137 207.81.254.137 netmask 255.255.255.240
ip nat inside source route-map nat-allow interface BVI32 overload
no ip http server
no ip http secure-server
ip classless
ip route 0.0.0.0 0.0.0.0 207.81.254.129
ip access-list extended internet-facing
permit udp host 192.5.41.40 host 207.81.254.137 eq ntp
permit udp host 192.5.41.41 host 207.81.254.137 eq ntp
permit tcp any 207.81.254.128 0.0.0.15 eq www
permit tcp any 207.81.254.128 0.0.0.15 eq 993
permit tcp any 207.81.254.128 0.0.0.15 eq pop3
permit tcp any 207.81.254.128 0.0.0.15 eq smtp
deny ip any any
11 Replies 11
Reza Sharifi
So, to summarize you are trying to apply these access-lists
to interface FastEthernet0/1.4 and BVI32, BVI32 takes the command but not fa0/1.4, right?
Sort of. I wrote it a little wrong. Almost.
1.) I want:
...To apply to FastEthernet 0/0. They used to be on "Dialer 1" which was attached to FastEthernet 0/0 but now FE 0/0 is a L2 bridge.
2.) I don't think it matters if they're on BVI32 or not since it's NATing and these ACLs were made for the public /28 block but yes I have it on that interface too.
So #1 above is really my priority.
Because: Right now I am Wide open. I can Ping, SSH, whatever... to ANY of the IPs on the /28 and it's scaring me. I need that extended access-list called "internet-facing" to take hold.
Thank you.
But yes, Fast Ethernet 0/1.4 is where my public IPs are and what I need protected BUT as with before I think the ACL should be on the "most wan address" which used to be the Dialer and is now the FastEthernet 0/0. It's just not taking. Thanks.
Joe
It appears the access-group "internet-facing" is now applying TO my nat overload IP instead of the public ip's (/28). It's supposed to apply to Those. Any idea?
commandlinekid
What I think is now happening: The ACL is Only being applied to the NAT stuff. It's not being applied to anything going over that bridge group. Is that because it's L2? Fine...but how on earth is this a reasonable solution when of Course we need an ACL to apply to traffic?
So how do I take this subnet assiged to a router on the other side of my bridge (the ISP), who is using the first usable IP as the router... and use the rest of the addresses On my virtual interface FE 0/1.4? With an ACL?
Please advise. Thanks
So, when the ACL is applied on the BVI, it is not effective at all?
Do you see the ACL counter increasing at all by using "sh ip access-list <name of the access list>"
HH
Hi.
1.) The access-list counter is only showing (and incrementing) for the One "overload IP" I have set on the BVI which means.... only NAT traffic is being seen I believe by that ACL.
2.) Can you please clarify ....should the gateway router of my devices using the /28 (hanging off FE 0/1.4) be the address I have configured for the BVI? I did (until just now) have it set to the first IP in the /28 which my ISP is holding on their side). This IP on the BVI also happens to be the NAT overload but separate thing. I read somewhere this should be the case. What I notice if I do this is weird: The ACL, if I make it have Nothing at all in it (empty) will allow all packets to pass for the "real ips" on FE 0.1.4. BUT...if I put in even one little thing there like say "eq icq" or something I'm not using... it makes the gateway unreachable and from a server pinging says "destination unreachable."
Since the servers IPs are in the subnet as the provider IP address .129
The gateway for all your servers should be .129 and not the BVI's IP address (.137)
The problem is if I don't use .137 the traffic appears to skip right over that ACL. It isn't even addressed.
Can you help me understand this? When I had a traditional ACL it made sense. Now it seems like with this setup "in is out" and "out is in." The only way the ACL works is if I write it almost backwards. I don't get it.
