Help with DHCP
astridrhea19
Hi everyone, I have this practice assignment I'm doing on PT and I can't seem to get my cisco router thats the DHCP server to work. I've spent hours on it and can't seem to figure it out, If anyone can please look at some of the config files I have to see what I've done wrong.
I have the "Edge Router" as the server with R2 and R1 connected to it. R1 has its own switch and R2 is connected to the main switch. I do have 2 other switches but I don't think they are the issue so I did not bother to post them here. The routers can all ping each other and the switches on the same LAN can ping each other as well, Although, I can't seem to ping the R1 switch to anyone.
Thank you for any help or Tips anyone can give.
Great exercise.
What you need to do is install route on the Edge router like this:
ip route 192.168.40.0 255.255.255.0 192.168.2.2
Just repeat it for the others vlans.
As you can see bwlow, the PC on vlan 40 is getting IP address.
C:\>ipconfig
FastEthernet0 Connection:(default port)
Connection-specific DNS Suffix..: NCC.edu
Link-local IPv6 Address.........: FE80::2D0:D3FF:FE1B:DC8B
IPv6 Address....................: ::
IPv4 Address....................: 192.168.40.30
Subnet Mask.....................: 255.255.255.0
Default Gateway.................: :: 192.168.40.1
6 Replies 6
Attached the .pkt file zipped. If device has credential please provide.
Thank you so much for the help.
Great exercise.
C:\>ipconfig
I can't believe that was it. The routing is the last thing in the packet and getting the hosts to get their DHCP is before that, now i have no idea why they set it up like this. THANK YOU!
Despite existing  a Layer 3 communication between routers, 192.168.2.1 and 192.168.2.2, when a machine sends a DHCP request, this request is sent through the vlan 40, which is 192.168.40.0.  Then, the EDGE router doesn´t know what do to with the packet cause it does not have route to the 192.168.40.0.  The same for all vlans.
Thank you for explaining this, truly.
