Help with HSRP On Cisco 867
KieranBilling
I wonder if anyone is able to assist with a HSRP issue I currently have
i have 2 Cisco 867 Router's with 5 vlan's on each.
I am currently having issue with HSRP I am not receiving a HSRP "IN" on one of the routers. I have read various articles and tried all I can to resolve the issue but seem to be a bit stuck and any help would be appreciated.
RTR1 -> SG200-08 -> P2PLink -> SG200-28 -> RTR2
Both Routers are the same model and firmware version.
There are currently no ACL's on the interfaces as these have been removed.
The VLAN's are all connected on 1 link to the switch with trunk's passed through the P2P links.
If you need any more info please ask.
RTR1 (receiving and sending OK)
*Mar 14 14:04:40.234: HSRP: Vl20 Grp 20 Hello out 172.16.1.3 Standby pri 90 vIP 172.16.1.1
*Mar 14 14:04:40.474: HSRP: Vl1 Grp 1 Hello out 192.168.1.1 Standby pri 100 vIP 192.168.1.254
*Mar 14 14:04:40.670: HSRP: Vl30 Grp 30 Hello in 10.0.21.2 Active pri 100 vIP 10.0.21.1
*Mar 14 14:04:40.670: HSRP: Vl30 Grp 30 Coup out 10.0.21.3 Active pri 110 vIP 10.0.21.1
*Mar 14 14:04:40.670: HSRP: Vl30 Grp 30 Hello out 10.0.21.3 Active pri 110 vIP 10.0.21.1
*Mar 14 14:04:41.294: HSRP: Vl10 Grp 10 Hello in 10.0.20.2 Active pri 115 vIP 10.0.20.1
*Mar 14 14:04:41.630: HSRP: Vl20 Grp 20 Hello in 172.16.1.2 Active pri 100 vIP 172.16.1.1
*Mar 14 14:04:41.802: HSRP: Vl40 Grp 40 Hello out 10.0.22.3 Active pri 100 vIP 10.0.22.1
*Mar 14 14:04:41.902: HSRP: Vl1 Grp 1 Hello in 192.168.1.2 Active pri 110 vIP 192.168.1.254
RTR2 (Sending but not receiving)
*Mar 14 14:48:24.792: HSRP: Vl10 Grp 10 Hello out 10.0.20.2 Active pri 115 vIP 10.0.20.1
*Mar 14 14:48:26.120: HSRP: Vl1 Grp 1 Hello out 192.168.1.2 Active pri 110 vIP 192.168.1.254
*Mar 14 14:48:26.328: HSRP: Vl20 Grp 20 Hello out 172.16.1.2 Active pri 100 vIP 172.16.1.1
*Mar 14 14:48:27.064: HSRP: Vl30 Grp 30 Hello out 10.0.21.2 Active pri 100 vIP 10.0.21.1
*Mar 14 14:48:27.464: HSRP: Vl10 Grp 10 Hello out 10.0.20.2 Active pri 115 vIP 10.0.20.1
*Mar 14 14:48:28.616: HSRP: Vl1 Grp 1 Hello out 192.168.1.2 Active pri 110 vIP 192.168.1.254
*Mar 14 14:48:29.208: HSRP: Vl20 Grp 20 Hello out 172.16.1.2 Active pri 100 vIP 172.16.1.1
*Mar 14 14:48:29.576: HSRP: Vl30 Grp 30 Hello out 10.0.21.2 Active pri 100 vIP 10.0.21.1
*Mar 14 14:48:30.104: HSRP: Vl10 Grp 10 Hello out 10.0.20.2 Active pri 115 vIP 10.0.20.1
*Mar 14 14:48:31.400: HSRP: Vl1 Grp 1 Hello out 192.168.1.2 Active pri 110 vIP 192.168.1.254
*Mar 14 14:48:32.008: HSRP: Vl30 Grp 30 Hello out 10.0.21.2 Active pri 100 vIP 10.0.21.1
*Mar 14 14:48:32.072: HSRP: Vl20 Grp 20 Hello out 172.16.1.2 Active pri 100 vIP 172.16.1.1
Any help appreciated and look forward to getting this resolved :)
Kieran
Reza Sharifi
Can you post the config from both routers?
Please see attached the current config's.
Thanks for your help.
