Help with WOL
jmichaelstanley
Hoping I can find some help for an issue I'm running into trying to send Wake-on-LAN packets (magic packet) over my Cisco smart switch (SF250-48).  The device issuing the WOL packet and the device receiving it are both on the same subnet, same VLAN. Both are connected to the switch.
I'm 99.9% sure it's the switch that is causing the problem. When I swap it out for another brand of switch I'm able to issue the WOL packet and see the device turn on.  I'm sure there is some setting that must be enabled but I've looked high and low and still can't seem to get it to work.
0 Replies 0
