Hi CPU Utilization
Mmiselo
Good day,
We have a router (Cisco 2900 Series ) and we are  terminating L2P VPNs  (VPND) on it. We are getting the following processes when the CPU is high and they causing high CPU utilization
6    72013880     4251984      16936  7.83%  0.99%  0.75%   0 Check heaps
268    37765560     6420124       5882  2.95%  0.41%  0.35%   0 VTEMPLATE Backgr
May you please advise how can we resolve this problem.
Nel
That figures.
2911 is NOT rated for 100 Mbps.  What you're seeing is to-be-expected when you're trying to push more traffic through your router's CPU is rated for.
If you want 100 Mbps link, then you should be looking at a 3925E or a 3945.
11 Replies 11
Leo Laohoo
Post the following output:
1.  sh version;
2.  sh proc cpu sorted | ex 0.00
*************************************sh version***************************************
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(4)M7, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 16-Sep-13 01:11 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M15, RELEASE SOFTWARE (fc1)
VPNROUTERNS02 uptime is 23 weeks, 1 day, 6 hours, 7 minutes
System returned to ROM by reload at 03:12:46 SAST Thu May 15 2014
System restarted at 03:13:59 SAST Thu May 15 2014
System image file is "flash:c2900-universalk9-mz.SPA.151-4.M7.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2911/K9 (revision 1.0) with 483328K/40960K bytes of memory.
Processor board ID FCZ1604704Y
3 Gigabit Ethernet interfaces
2 Serial(sync/async) interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2911/K9          FCZ1604704Y
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      securityk9    Permanent      securityk9
uc            None          None           None
data          None          None           None
***********************************sh proc cpu sorted | ex 0.00********************************
sh processes cpu sort | ex 0.00
CPU utilization for five seconds: 73%/29%; one minute: 69%; five minutes: 68%
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
129  1761524224   564662083       3119 30.39% 30.28% 30.23%   0 IP Input
268    39723928     6601570       6017  6.79%  1.04%  0.71%   0 VTEMPLATE Backgr
303   168717824   372212068        453  1.27%  1.23%  1.21%   0 L2TP mgmt daemon
302    37251856   789483188         47  0.95%  1.04%  1.05%   0 L2X Data Daemon
326    61282972   435145344        140  0.55%  0.55%  0.57%   0 RADIUS
115    17016076   135792453        125  0.55%  0.58%  0.57%   0 ACCT Periodic Pr
   3         552         387       1426  0.39%  0.17%  0.04% 388 SSH Process
320    45983760   171286016        268  0.31%  0.37%  0.36%   0 IP SNMP
317    20141956   462660050         43  0.31%  0.34%  0.32%   0 PPP Events
114     9963516   139895251         71  0.23%  0.26%  0.25%   0 AAA ACCT Proc
195     1864548  3106945023          0  0.23%  0.24%  0.23%   0 HQF Shaper Backg
153     2421744    20569783        117  0.15%  0.16%  0.15%   0 CEF: IPv4 proces
136        5740        1164       4931  0.15%  2.23%  1.16% 389 SSH Process
100     1689852  1605894648          1  0.15%  0.13%  0.15%   0 Ethernet Msec Ti
316     1764360   425462095          4  0.07%  0.06%  0.07%   0 PPP manager
137    12012444    25163738        477  0.07%  0.09%  0.07%   0 SSS Manager
322    24268536    85558321        283  0.07%  0.18%  0.18%   0 SNMP ENGINE
304    13071736    28233830        462  0.07%  0.09%  0.08%   0 L2TUN Applicatio
240    18890632    19936499        947  0.07%  0.10%  0.10%   0 Crypto IKMP
  67     2102080    14040478        149  0.07%  0.07%  0.07%   0 Per-Second Jobs
CPU utilization for five seconds: 71%/29%; one minute: 69%; five minutes: 68%
129  1761527304   564662755       3119 27.48% 30.06% 30.18%   0 IP Input
268    39724492     6601576       6017  7.06%  1.52%  0.82%   0 VTEMPLATE Backgr
   6    75220152     4426664      16992  1.27%  0.84%  0.75%   0 Check heaps
303   168717920   372212222        453  1.19%  1.22%  1.21%   0 L2TP mgmt daemon
302    37251900   789483464         47  0.95%  1.03%  1.05%   0 L2X Data Daemon
115    17016124   135792507        125  0.63%  0.58%  0.57%   0 ACCT Periodic Pr
326    61283008   435145462        140  0.39%  0.54%  0.57%   0 RADIUS
136        5764        1191       4839  0.39%  2.08%  1.15% 389 SSH Process
317    20141968   462660225         43  0.31%  0.33%  0.32%   0 PPP Events
114     9963516   139895309         71  0.23%  0.26%  0.25%   0 AAA ACCT Proc
153     2421748    20569793        117  0.15%  0.16%  0.15%   0 CEF: IPv4 proces
137    12012456    25163758        477  0.15%  0.09%  0.08%   0 SSS Manager
304    13071752    28233850        462  0.15%  0.10%  0.08%   0 L2TUN Applicatio
195     1864552  3106945766          0  0.15%  0.23%  0.23%   0 HQF Shaper Backg
320    45983840   171286751        268  0.15%  0.35%  0.36%   0 IP SNMP
316     1764360   425462245          4  0.07%  0.06%  0.07%   0 PPP manager
142     3622212    40704663         88  0.07%  0.02%  0.01%   0 SSM connection m
165     4933920     9924475        497  0.07%  0.04%  0.02%   0 IP Background
  67     2102084    14040484        149  0.07%  0.07%  0.07%   0 Per-Second Jobs
240    18890640    19936512        947  0.07%  0.10%  0.10%   0 Crypto IKMP
100     1689856  1605895081          1  0.07%  0.13%  0.15%   0 Ethernet Msec Ti
322    24268640    85558689        283  0.07%  0.17%  0.18%   0 SNMP ENGINE
CPU utilization for five seconds: 70%/29%; one minute: 69%; five minutes: 68%
129  1761543728   564664923       3119 32.31% 30.29% 30.24%   0 IP Input
  13    19378600      233310      83061  1.44%  0.18%  0.12%   0 Licensing Auto U
303   168718432   372212931        453  1.36%  1.17%  1.20%   0 L2TP mgmt daemon
302    37252212   789484865         47  0.96%  1.03%  1.05%   0 L2X Data Daemon
326    61283184   435146162        140  0.64%  0.56%  0.57%   0 RADIUS
115    17016300   135792798        125  0.64%  0.58%  0.57%   0 ACCT Periodic Pr
268    39724928     6601602       6017  0.40%  1.24%  0.81%   0 VTEMPLATE Backgr
317    20142052   462661089         43  0.32%  0.33%  0.32%   0 PPP Events
114     9963580   139895613         71  0.32%  0.26%  0.25%   0 AAA ACCT Proc
320    45984032   171287790        268  0.24%  0.43%  0.38%   0 IP SNMP
195     1864568  3106949982          0  0.24%  0.25%  0.24%   0 HQF Shaper Backg
137    12012500    25163827        477  0.16%  0.09%  0.08%   0 SSS Manager
153     2421752    20569843        117  0.16%  0.16%  0.16%   0 CEF: IPv4 proces
322    24268768    85559208        283  0.16%  0.24%  0.20%   0 SNMP ENGINE
304    13071784    28233927        462  0.16%  0.10%  0.08%   0 L2TUN Applicatio
316     1764372   425463025          4  0.08%  0.06%  0.08%   0 PPP manager
165     4933940     9924506        497  0.08%  0.03%  0.02%   0 IP Background
135     2782944     4311307        645  0.08%  0.05%  0.05%   0 PPP IP Route
  67     2102088    14040516        149  0.08%  0.08%  0.08%   0 Per-Second Jobs
142     3622212    40704772         88  0.08%  0.02%  0.01%   0 SSM connection m
100     1689868  1605897460          1  0.08%  0.13%  0.15%   0 Ethernet Msec Ti
it's 100Mbps
That figures.
Mmiselo
10 Gbps is confirmed as supposed to the value I sent. So this is still the case as per your advice.
So 2911 is still NOT rated for 10Gbps?
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Nope.  Cisco recommends a 2911 for up to 35 Mbps (duplex).  Although Cisco also documents the 2911 can forward up to 3.371 Gbps, the 35 Mbps is for real world usage.
For routers, for 10G, you would need to look at the ASR 1K series.
Thanks a lot Leo and Joseph for your assistance!
I agree with Joseph.  If you want 10 Gbps bandwidth then you are potentially looking at an ASR 1002-X.
Thanks a lot!
