01-14-2008 11:31 AM - edited 03-05-2019 08:28 PM
I see verfy high cpu utilization on my 4507 switch
The sh proc cpu shows the catmgmt -lo priority process with high utilization
the show platform health shows high utilization for the KxAclPathMan create/ process
after reading the troubleshooting guide it points to see whether there are any interface flaps but i do not see any
Any inputs will help
SUPV
IOS - 12.1 20 EW2
Ambi
Solved! Go to Solution.
01-22-2008 04:05 AM
Have you enabled looging even link-status under your interfaces?
4500 does not show any interface flaps if the above command has been configured
Narayan
01-14-2008 04:10 PM
Maybe this can point you in the correct direction . If not check the bug toolkit.
http://www.cisco.com/en/US/products/hw/switches/ps663/products_tech_note09186a00804cef15.shtml
01-22-2008 04:05 AM
Narayan
