Hi Guys,
Im facing high RP CPU but im unable to tell which traffic is causing.
sh proc cpu
CPU utilization for five seconds: 95%/74%; one minute: 93%; five minutes: 92%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
260 18198348683633142802 0 5.27% 1.95% 2.15% 0 SNMP ENGINE
12 20179438563103711806 0 3.91% 4.07% 4.04% 0 ARP Input
24 12651289442771501964 0 2.07% 1.78% 1.74% 0 IPC Seat Manager
560 1282542540 373138232 3437 1.91% 2.41% 2.31% 0 Port manager per
328 9746311203977962122 0 1.59% 1.75% 1.77% 0 IP Input
330 10350723522267427981 0 1.11% 1.26% 1.28% 0 ADJ resolve proc
410 333079676 107170941 3107 0.71% 0.65% 0.65% 0 CEF: IPv4 proces
322 89262516 215671860 413 0.39% 0.63% 0.64% 0 CDP Protocol
616 227367481726024960 13 0.39% 0.39% 0.39% 0 VRRP
254 3137825001970405200 159 0.31% 0.29% 0.29% 0 IP SNMP
368 126109100 44009810 2865 0.31% 0.18% 0.17% 0 QOS Stats Gather
352 54758083677544205 0 0.23% 0.22% 0.23% 0 Ethernet Msec Ti
170 35404 6798 5208 0.23% 0.23% 0.22% 1 SSH Process
61 960399082178699930 0 0.23% 0.20% 0.20% 0 VSIBC process
504 122968883383422803 0 0.23% 0.18% 0.18% 0 IP SLAs Event Pr
88 119296624 207453362 575 0.15% 0.18% 0.16% 0 ARP HA
617 42620283812256236 1 0.15% 0.14% 0.15% 0 HSRP Common
52 16900792 65833906 256 0.15% 0.13% 0.15% 0 Per-Second Jobs
2 215832 12657854 17 0.07% 0.01% 0.00% 0 Load Meter
#sh mls rate-limit
Sharing Codes: S - static, D - dynamic
Codes dynamic sharing: H - owner (head) of the group, g - guest of the group
Rate Limiter Type Status Packets/s Burst Sharing
MCAST NON RPF Off - - -
MCAST DFLT ADJ On 100000 100 Not sharing
MCAST DIRECT CON Off - - -
ACL BRIDGED IN Off - - -
ACL BRIDGED OUT Off - - -
IP FEATURES Off - - -
ACL VACL LOG On 5000 1 Not sharing
MAC PBF IN Off - - -
CEF RECEIVE Off - - -
CEF GLEAN On 200 50 Not sharing
MCAST PARTIAL SC On 100000 100 Not sharing
IP RPF FAILURE On 1000 20 Group:0 S
TTL FAILURE On 15 10 Not sharing
ICMP UNREAC. NO-ROUTE On 1000 20 Group:0 S
ICMP UNREAC. ACL-DROP On 1000 20 Group:0 S
ICMP REDIRECT On 20000 20 Not sharing
MTU FAILURE On 100 10 Not sharing
MCAST IP OPTION Off - - -
UCAST IP OPTION Off - - -
LAYER_2 PDU Off - - -
LAYER_2 PT Off - - -
LAYER_2 PORTSEC Off - - -
LAYER_2 MiniProto Off - - -
DHCP Snooping IN Off - - -
DHCP Snooping OUT Off - - -
ARP Inspection Off - - -
IP ERRORS On 1000 20 Group:0 S
CAPTURE PKT Off - - -
MCAST IGMP On 20000 40 Not sharing
MCAST IPv6 DIRECT CON Off - - -
MCAST IPv6 ROUTE CNTL On 1000 20 Group:8 D/g
MCAST IPv6 *G M BRIDG Off - - -
MCAST IPv6 SG BRIDGE Off - - -
MCAST IPv6 DFLT DROP On 1000 20 Group:8 D/H
MCAST IPv6 SECOND. DR Off - - -
MCAST IPv6 *G BRIDGE Off - - -
MCAST IPv6 MLD Off - - -
IP ADMIS. ON L2 PORT Off - - -
UCAST IP TINY FRAG Off - - -
MCAST IP TINY FRAG Off - - -
UCAST UNKNOWN FLOOD Off - - -
MCAST IPv4 PIM Off - - -
IPV6 BRIDGE Off - - -
Thanks in advance
Solved! Go to Solution.
Thanks for your suggestion.
I have found the root cause, it was due to one of the internal ips attacking 100+ plus of icmp packets to outside.
Thanks.
Hi!
Thanks for your help.
VSS#sh proc cpu sort | ex 0.00
CPU utilization for five seconds: 96%/76%; one minute: 95%; five minutes: 95%
260 18201234683633322894 0 4.79% 3.11% 2.54% 0 SNMP ENGINE
12 20185258003103866704 0 4.07% 4.18% 4.09% 0 ARP Input
330 10352666282267620370 0 1.51% 1.45% 1.42% 0 ADJ resolve proc
328 9748778283978140081 0 1.51% 1.58% 1.63% 0 IP Input
560 1282866816 373419606 3435 1.27% 2.27% 2.31% 0 Port manager per
322 89364712 215685973 414 0.63% 0.69% 0.65% 0 CDP Protocol
24 12654220762771756467 0 0.55% 1.84% 1.76% 0 IPC Seat Manager
397 27132876 49726110 545 0.55% 0.68% 0.61% 0 XDR mcast
616 227985841726106414 13 0.39% 0.39% 0.39% 0 VRRP
368 126134588 44012091 2865 0.31% 0.18% 0.17% 0 QOS Stats Gather
254 3138226241970462838 159 0.31% 0.37% 0.32% 0 IP SNMP
238 6840672 258038737 26 0.23% 0.26% 0.24% 0 IPv6 ND
421 25475340 78059125 326 0.23% 0.22% 0.21% 0 L3 Manager
398 125191488 59353908 2109 0.23% 0.18% 0.18% 0 IPC LC Message H
352 54911563677949895 0 0.23% 0.21% 0.22% 0 Ethernet Msec Ti
504 123232763383728169 0 0.23% 0.19% 0.18% 0 IP SLAs Event Pr
88 119325956 207467056 575 0.15% 0.17% 0.16% 0 ARP HA
271 21766516 281773852 77 0.15% 0.12% 0.13% 0 cpf_process_tpQ
617 42732643812457122 1 0.15% 0.14% 0.15% 0 HSRP Common
61 960569602178851315 0 0.15% 0.22% 0.22% 0 VSIBC process
52 16920964 65838113 257 0.15% 0.13% 0.14% 0 Per-Second Jobs
21 9656236 63223969 152 0.07% 0.07% 0.07% 0 IPC Periodic Tim
430 18876868 213123970 88 0.07% 0.07% 0.07% 0 ISIS Upd sparks
423 10098632 122060816 82 0.07% 0.10% 0.08% 0 FM core
259 824088321003662711 82 0.07% 0.08% 0.07% 0 PDU DISPATCHER
361 50476012 317639422 158 0.07% 0.10% 0.09% 0 ISIS Adj sparks
297 33704281958220946 1 0.07% 0.05% 0.06% 0 ACE Tunnel Task
278 1863604 250899673 7 0.07% 0.04% 0.05% 0 Transport Port A
VSS#
#sh version
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVENTERPRISEK9-M), Version 12.2(33)SXJ9, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Mon 16-Mar-15 14:07 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX7, RELEASE SOFTWARE (fc1)
VSS uptime is 2 years, 2 days, 14 hours, 59 minutes
Uptime for this control processor is 2 years, 2 days, 14 hours, 9 minutes
Time since VSS switched to active is 2 years, 2 days, 14 hours, 10 minutes
System returned to ROM by reload at 01:54:46 UTC Tue Jan 25 2000 (SP by reload)
System restarted at 00:49:15 SGT Sat Feb 3 2018
System image file is "sup-bootdisk:s72033-adventerprisek9-mz.122-33.SXJ9.bin"
Last reload reason: Reason unspecified
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509-E (R7000) processor (revision 1.4) with 983008K/65536K bytes of memory.
Processor board ID SMG1133N63V
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
37 Virtual Ethernet interfaces
246 Gigabit Ethernet interfaces
36 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Thanks.
