11-29-2016 10:19 PM - editado 03-08-2019 08:22 AM
el 11-29-2016 10:44 PM
Kindly post the complete output to the command "sh proc cpu sort | ex 0.00".
el 11-30-2016 06:09 PM
CPU utilization for five seconds: 99%/0%; one minute: 99%; five minutes: 99%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
57 810046681051264210 77 95.87% 95.74% 95.35% 0 Cat4k Mgmt LoPri
56 155205996 685055848 226 2.61% 2.55% 2.60% 0 Cat4k Mgmt HiPri
64 27232415 266779588 102 0.39% 0.33% 0.35% 0 Net Input
133 15287027 39972956 382 0.23% 0.18% 0.16% 0 Spanning Tree
14 4955288 26538602 186 0.07% 0.08% 0.07% 0 ARP Input
41 12762968 9409144 1356 0.07% 0.08% 0.07% 0 IDB Work
174 1237624 13714191 90 0.07% 0.05% 0.05% 0 CEF: IPv4 proces
el 11-29-2016 10:58 PM
Hi ,
These two processes seem to be the culprits :
56 153874756 680837438 226 2.61% 2.65% 2.69% 0 Cat4k Mgmt HiPri
57 363174821047547247 34 95.64% 95.42% 95.32% 0 Cat4k Mgmt LoPri
We would need the output of "sh plat health"
This seems to be a fairly common issue as documented by CISCO here :
This is documented here : http://www.cisco.com/c/en/us/support/docs/switches/catalyst-4000-series-switches/65591-cat4500-high-cpu.html
Several entries are available on supportforums for this issue.
https://supportforums.cisco.com/discussion/11730586/high-cpu-utilization-cisco-ios-catalyst-4500
P.S. Don't forget to mark the correct answers !
el 11-30-2016 05:56 PM
Descubra y salve sus notas favoritas. Vuelva a encontrar las respuestas de los expertos, guías paso a paso, temas recientes y mucho más.
¿Es nuevo por aquí? Empiece con estos tips. Cómo usar la comunidad Guía para nuevos miembros
