High CPU utilization due to IP Input
jarar_m01
Level 2
Level 2
Hi guys... please help me fix this issue. I get High CPU utilization on my
C3750E Software (C3750E-IPBASEK9-M), Version 15.0(2)SE10a, RELEASE SOFTWARE (fc3)
Can any one help me with the solution. I tried to check on support forums but its still not resolved. I had the same issue on 3550 so Replaced it with 3750 but still the same.
Any help will be appreciated.
18 Replies 18
Mark Malone
Hi what's connected to this switch , is it servers or just users pcs and phones ?
theres a few things to check in this doc if you have not seen it , did you capture a dhow tech when the issue was like this , run it through the cli analyser too
http://www.cisco.com/c/en/us/support/docs/routers/7500-series-routers/41160-highcpu-ip-input.html
Hi Mark,
This is my core switch for a small site. However, the design is not pretty good and I have joined here recently.. I will be changing the Infrastructure. But need to fix this untill that is done.
I went through the document but everything seems fine. Also the switch is behaving weird. Its 99 % for a moment and other 5 seconds its 33 %.
you could try another software release to rule that out too even though your on the latest , issue with being on the latest you may be hitting a bug and its not known , push another one into flash you could always easily roll back to the se10 , is it always ip input when it spikes to 99%
as its a core is there much server traffic , are the interfaces overloading at times ? do you monitor this switch at all with any 3rd party apps
Yes i keep monitoring this as my Solarwinds keeps poping alerts. However, I replaced this switch 2 days ago. I was using 3550 before this one and i replaced it because it had the same issue of high CPU utilization.
The performance of the network is fine but I just want to fix this issue. If IoS was the issue i wonder why my old switch has the same problem.
Yes understood with software just an option to rule out , 3750s aren't core switches really , there access/dist and have very low buffers that's why I was wondering whats connected to it and how much traffic it is pushing , it may be under spec for a core if there are servers connected
aswell if its only spiking the odd time you may not be able to fix it , some traffic can cause this as its not cef switched and is punted directly to the cpu and can cause temporary spikes in the cpu , if its sitting over 60-70% constantly then you have an issue
the fact you have 26% interrupt traffic at the same time it spikes indicates its struggling at that time to process everything
if it was a larger switch we could do a netdr capture and see exactly what is being punted to the cpu but the lower end 3 series don't support this
I have enabled CEF too but its not helping 😞 ... Let me get more details on my own research and update here... But you are a great help. Thank you for responding my query please keep an eye on this post I will update you soon...
If not i will simply get Nexus 7k 😛
haha yes stick in a 7k or 2 🙂
do you have access to the cli analyser you can run the show tech through it see if it picks something up ? if not I can run it for you but you need to capture the show tech while its high
heres a script you can run save you trying to capture real time , basically when cpu hits 70% it will run the below script collect all the commands below dump it into a text file you can then pull from flash so you have all the stats as the switch is effected
event manager applet High_CPU
    event snmp oid 1.3.6.1.4.1.9.9.109.1.1.1.1.4.1 get-type exact entry-op ge entry-val "70" exit-time 10 poll-interval 5
    action 0.1 syslog msg "CPU Utilization is high"
    action 0.2 cli command "enable"
    action 0.4 cli command "show log | append flash:CPU_Profile.txt"
    action 0.5 cli command "show process cpu sorted | append flash:CPU_Profile.txt"
    action 0.6 cli command "show interfaces | append flash:CPU_Profile.txt"
    action 0.7 cli command " show ip cef switching stat | append flash:CPU_Profile.txt"
    action 0.8 cli command " show tech | append flash:CPU_Profile.txt"
    action 0.9 cli command " show int switching | append flash:CPU_Profile.txt"
    action 1.0 cli command "no event manager applet High_CPU"
    action 1.1 cli command "end"
Cisco tools link
http://www.cisco.com/c/en/us/support/web/tools-catalog.html
This sounds cool let me get back to you with results.
I downloaded CLI analyzer and it says no issues found when i used System Diagnostics and the same time the CPU was on 99 %
however i have also configured the EEM you requested but its not appending any output.. I keep getting the following messages:
005902: 3d18h: %HA_EM-6-LOG: High_CPU: CPU Utilization is high
005903: 3d18h: %HA_EM-6-LOG: High_CPU: CPU Utilization is high
005904: 3d18h: %HA_EM-6-LOG: High_CPU: CPU Utilization is high
005905: 3d18h: %HA_EM-6-LOG: High_CPU: CPU Utilization is high
005906: 3d18h: %HA_EM-6-LOG: High_CPU: CPU Utilization is high
005907: 3d18h: %HA_EM-6-LOG: High_CPU: CPU Utilization is high
005908: 3d18h: %HA_EM-6-LOG: High_CPU: CPU Utilization is high
005909: 3d18h: %HA_EM-6-LOG: High_CPU: CPU Utilization is high
005910: 3d18h: %HA_EM-6-LOG: High_CPU: CPU Utilization is high
hi
what does it show in flash , is the file there ?
dir flash:
Directory of flash:/
2 -rwx 1876 Jan 2 2006 04:29:53 +04:00 vlan.dat
3 -rwx 20439040 Mar 1 1993 07:50:39 +04:00 c3750e-ipbasek9-mz.150-2.SE10a.bin
4 drwx 512 Sep 25 2013 04:10:44 +04:00 crashinfo_ext
11 -rwx 6168 Jan 23 2017 09:26:26 +04:00 multiple-fs
12 drwx 512 Mar 1 1993 04:30:04 +04:00 c3750e-universal-mz.122-52.SE
444 -rwx 12751 Jan 23 2017 09:26:26 +04:00 config.text
435 drwx 512 Mar 1 1993 04:00:08 +04:00 crashinfo
443 -rwx 3705 Jan 23 2017 09:26:26 +04:00 private-config.text
57671680 bytes total (6240768 bytes free)
did it all take in cli ok it sent the syslog which is action 1.0 strange the rest didn't kick in and send to flash   , its in show run the whole script it took ok
you can try this one either I had saved , it was
event manager session cli username "MMALONE"
event manager applet HIGH_CPU
 event snmp oid 1.3.6.1.4.1.9.9.109.1.1.1.1.3.1 get-type exact entry-op ge entry-val "70" poll-interval 30
 action 0.0 syslog msg "High CPU Detected"
 action 0.1 cli command "enable"
 action 0.2 cli command "show clock | append flash:HIGH_CPU.txt"
 action 0.3 cli command "show tech | append flash:HIGH_CPU.txt "
 action 0.4 cli command "show logging | append flash:HIGH_CPU.txt "
 action 0.5 cli command "show process cpu sorted | append flash:HIGH_CPU.txt "
 action 0.6 cli command "show process cpu history | append flash:HIGH_CPU.txt"
 action 0.7 cli command "show buffers| append flash:HIGH_CPU.txt"
 action 0.8 cli command "show platform health | append flash:HIGH_CPU.txt "
 action 0.9 cli command "show platform cpu packet statistics all | append flash:HIGH_CPU.txt "
 action 1.0 cli command "show platform cpu packet buffered | append flash:HIGH_CPU.txt "
Okay let me configure this one and hopefully come back to you with results.
