High THREAD-process load on Cat6509
aneumann
The Cat6509 runs CatOS 6.4(13) The command "sho proc cpu" shows sometimes that:
CPU utilization for five seconds: 54.32%
one minute: 32.85%
five minutes: 27.46%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
1 0 0 0 45.68% 67.15% 72.54% -2 Kernel and Idle
2 23 265 4000 0.00% 0.00% 0.00% -2 Flash MIB Updat
3 0 1 0 0.00% 0.00% 0.00% -2 L2IntHdlr
2000 0.00% 0.00% 0.00% -2 SWPoll64bCnt
15 378927 2969088 1000 0.00% 0.00%
34 33 629 1000 0.00% 0.00% 0.00% -2 SnmpTraps
35 0 1 0 0.00% 0.00% 0.00% -2 Acct Send Bkg
36 5 7 2000 0.00% 0.00% 0.00% -2 l2t_server
37 336281892 3278987842 2000 0.52% 0.00% 0.00% -2 Authenticator_S
38 0 1 0 0.00% 0.00% 0.00% -2 dot1x_rx
39 2092385 194008893 2000 0.00% 0.00% 0.00% -2 Backend_Rx
40 413353141 1250098212 2000 0.48% 0.00% 0.00% -2 Backend_SM
42 86545 2737 168000 0.00% 0.00% 0.00% -2 SysLogTask
43 10689996 65093953 72000 0.04% 0.00% 0.00% -2 NetFlow
44 28942300 294123494 2000 0.06% 0.00% 0.00% -2 L3Aging
45 0 1 0 0.00% 0.00% 0.00% -2 MlsHa
46 2469039 88427878 2000 0.00% 0.00% 0.00% -2 pinggateA
47 23140303 41713574 5000 0.00% 0.00% 0.00% -2 cdpd
48 1195955506 88811366 39000 1.32% 1.00% 1.00% -2 cdpdtimer
49 695708578 88880059 35000 0.60% 0.00% 0.00% -2 SptTimer
50 2330543755 197939235 121000 0.00% 0.00% 0.00% -2 SptBpduRx
51 3775310229 164877969 114000 9.42% 7.76% 7.95% -2 SptBpduTx
52 14286385 91657915 3000 0.00% 0.00% 0.00% -2 VtpTimer
53 4391854 677183393 20000 0.00% 0.00% 0.00% -2 RouterConfig
54 0 1 0 0.00% 0.00% 0.00% -2 RMON AlarmTimer
55 0 1 0 0.00% 0.00% 0.00% -2 sptTraps
56 0 1 0 0.00% 0.00% 0.00% -2 M-MLS_stats
57 11 34 1000 0.00% 0.00% 0.00% -2 M-MLS_manager
58 78662 741917 8000 0.00% 0.00% 0.00% -2 QoSTask
59 146360277 408039188 2000 0.20% 0.00% 0.00% 0 Read Stats Task
60 213123 8880068 2000 0.00% 0.00% 0.00% 0 QDE Task
61 6831577 49481 325000 0.00% 0.00% 0.00% -2 NvramMonitor
62 7 1 7000 0.00% 0.00% 0.00% -2 HPActive
63 0 1 0 0.00% 0.00% 0.00% -2 HPTrapMgr
143 889207 13951503 886000 0.00% 0.00% 0.00% 0 Console
144 27007877 81786491 223000 3.20% 1.76% 1.95% -2 snmpdm
145 1700786 10580185 100000 0.00% 0.00% 0.00% -2 VtpRx
146 345620944 126115730 26000 32.84% 18.76% 9.60% -2 THREAD
147 117574 76 3000 0.00% 0.00% 0.00% 2191630868 telnet147
148 254071 1897 101000 4.72% 3.84% 3.96% 2191167764 telnet148
156 5796 904 201000 0.00% 0.00% 0.00% -2 AclManager
Is the switch lacking of power?
Thank you for your help
Fred
htarra
Level 4
Level 4
No your switch is not lacking of any power. Normally, the high cpu was caused by enabling rpf on a GE interface and removing it, the procees that was high was the FIB, switch5 > (enable) sho proc cpu.
What does rpf do? Is that enabled in a constant intervall? I have sometimes funny ping-replies to that switch (see attach.). Any idea? Thx.
avmabe
Level 3
Level 3
Are you running BGP?
What version of SUP720 do you have? (a, b, bxl)
No BGP. No SUP720, it is an old SupVis1a WS-X6K-SUP1A-2GE
