High throttle count on interface
NInja Black
 I am seeing high throttle count on my router interface facing the ISP router. I read online and understood that it could be due to us switching to NVI NAT instead of classic NAT.
Is there a way I can troubleshoot this and bring the count to 0? Put in the outputs for 'sh run int g0/1' and 'sh buffers'
Router3925#sh int g0/1
GigabitEthernet0/1 is up, line protocol is up
  Hardware is PQ3_TSEC, address is e4c7.22fd.fa01 (bia e4c7.22fd.fa01)
  Description: EDI_Link
  Internet address is xx.xx.xx.xx/30
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
     reliability 255/255, txload 3/255, rxload 17/255
  Keepalive set (10 sec)
  Full Duplex, 100Mbps, media type is RJ45
  output flow-control is unsupported, input flow-control is unsupported
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 0/75/253482/0 (size/max/drops/flushes); Total output drops: 2591
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 6812000 bits/sec, 909 packets/sec
  5 minute output rate 1240000 bits/sec, 1130 packets/sec
     920523914 packets input, 886926148382 bytes, 0 no buffer
     Received 1863 broadcasts (0 IP multicasts)
     0 runts, 0 giants, 118667 throttles
     0 watchdog, 0 multicast, 0 pause input
     947819052 packets output, 165145738343 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
     0 unknown protocol drops
     1 lost carrier, 0 no carrier, 0 pause output
#sh buff
Buffer elements:
     1655 in free list
     24949289 hits, 0 misses, 1242 created
Public buffer pools:
Small buffers, 104 bytes (total 50, permanent 50, peak 65 @ 3w4d):
     47 in free list (20 min, 150 max allowed)
     5068475 hits, 5 misses, 15 trims, 15 created
     0 failures (0 no memory)
Middle buffers, 600 bytes (total 25, permanent 25, peak 70 @ 2w5d):
     24 in free list (10 min, 150 max allowed)
     44487 hits, 54 misses, 162 trims, 162 created
Big buffers, 1536 bytes (total 50, permanent 50, peak 51 @ 3w4d):
     50 in free list (5 min, 150 max allowed)
     222173 hits, 0 misses, 1 trims, 1 created
VeryBig buffers, 4520 bytes (total 10, permanent 10, peak 11 @ 3w4d):
     10 in free list (0 min, 100 max allowed)
     124 hits, 0 misses, 1 trims, 1 created
Large buffers, 5024 bytes (total 1, permanent 0, peak 1 @ 3w4d):
     1 in free list (0 min, 10 max allowed)
     0 hits, 0 misses, 229 trims, 230 created
Huge buffers, 18024 bytes (total 5, permanent 0, peak 5 @ 3w4d):
     5 in free list (4 min, 10 max allowed)
     0 hits, 0 misses, 458 trims, 463 created
Interface buffer pools:
CF Small buffers, 104 bytes (total 101, permanent 100, peak 101 @ 3w4d):
     101 in free list (100 min, 200 max allowed)
Generic ED Pool buffers, 512 bytes (total 101, permanent 100, peak 101 @ 3w4d):
     101 in free list (100 min, 100 max allowed)
     0 hits, 0 misses
CF Middle buffers, 600 bytes (total 101, permanent 100, peak 101 @ 3w4d):
Syslog ED Pool buffers, 600 bytes (total 133, permanent 132, peak 133 @ 3w4d):
     101 in free list (132 min, 132 max allowed)
     9483 hits, 0 misses
CF Big buffers, 1536 bytes (total 26, permanent 25, peak 26 @ 3w4d):
     26 in free list (25 min, 50 max allowed)
pak coalesce engine buffers, 1536 bytes (total 512, permanent 256, peak 512 @ 3w4d):
     0 in free list (0 min, 512 max allowed)
     384 hits, 128 misses, 0 trims, 256 created
     512 max cache size, 511 in cache
     843364860 hits in cache, 0 misses in cache
IPC buffers, 4096 bytes (total 2, permanent 2):
     1 in free list (1 min, 8 max allowed)
     1 hits, 0 fallbacks, 0 trims, 0 created
CF VeryBig buffers, 4520 bytes (total 3, permanent 2, peak 3 @ 3w4d):
     3 in free list (2 min, 4 max allowed)
CF Large buffers, 5024 bytes (total 2, permanent 1, peak 2 @ 3w4d):
     2 in free list (1 min, 2 max allowed)
IPC Medium buffers, 16384 bytes (total 2, permanent 2):
     2 in free list (1 min, 8 max allowed)
     0 hits, 0 fallbacks, 0 trims, 0 created
IPC Large buffers, 65535 bytes (total 17, permanent 16, peak 17 @ 3w4d):
     17 in free list (16 min, 16 max allowed)
     0 hits, 0 misses, 37177 trims, 37178 created
Header pools:
Header buffers, 0 bytes (total 768, permanent 768):
     256 in free list (128 min, 1024 max allowed)
     512 hits, 0 misses, 0 trims, 0 created
     512 max cache size, 512 in cache
     49163 hits in cache, 0 misses in cache
Particle Clones:
     1024 clones, 0 hits, 0 misses
Public particle pools:
F/S buffers, 256 bytes (total 768, permanent 768):
Normal buffers, 1548 bytes (total 3840, permanent 3840):
     3712 in free list (128 min, 4096 max allowed)
     896 hits, 0 misses, 0 trims, 0 created
Private particle pools:
HQF Particle buffers, 0 bytes (total 2000, permanent 2000):
     2000 in free list (500 min, 2000 max allowed)
     817878263 hits, 0 misses, 0 trims, 0 created
IDS SM buffers, 240 bytes (total 128, permanent 128):
     0 in free list (0 min, 128 max allowed)
     128 hits, 0 fallbacks
     128 max cache size, 128 in cache
GigabitEthernet0/0 buffers, 1664 bytes (total 768, permanent 768):
     0 in free list (0 min, 768 max allowed)
     768 hits, 0 fallbacks
     768 max cache size, 512 in cache
     988130117 hits in cache, 0 misses in cache
GigabitEthernet0/1 buffers, 1664 bytes (total 768, permanent 768):
     920677093 hits in cache, 0 misses in cache
GigabitEthernet0/2 buffers, 1664 bytes (total 768, permanent 768):
     1522570443 hits in cache, 0 misses in cache
5 Replies 5
Leo Laohoo
Your Input Queue (Drops) is abnormally high.
What appliance is this?
Thanks for the reply Leo.
Its a cisco 3925 ISR router.
Please advise on how to troubleshoot.
And what is the WAN bandwidth?
Its 50Mbps.
Hey Leo,
 Any tips on troubleshooting? Any insight is appreciated. Thanks
