08-15-2011 08:31 AM - edited 03-07-2019 01:42 AM
Hello Everyone!
I was doing network throughput using Fluke Etherscope II and LinkRunner Duo and noticed a strange phenomenon when using small frames up to 68 Bytes. There is a loss rate that goes up to 4 %. Increasing frame size up to 1000 or 1500 Bytes will eliminate any packet loss. It was tested on flat network using 6500 series switches with the 10 Gbps backbone connection. I attaches some pictures with the test results. Any idea why this happens?
Thank you,
Val
08-23-2011 09:29 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
It might be your queues' buffers are too small for a high rate of small packets.
