On User's Cat/OS, he has enabled LACP on modules 1 & 6 for a 4 Gb LACP aggregation. This works fine, but user now wants to connect individual hosts to remaining ports on module 6. I had the user issue "set port lacp-channel 6/3-18 mode off" on the non-aggregated ports. The hosts will not connect on ports 6/3-14, but do connect properly on 6/15-18. Speed/duplex/vlan assignment are all the same on the various ports. I'm having him also check media-type on these ports because there is a choice between copper and fiber.
