How do I remove banner?
jose.jimenez
Level 3
Level 3
How can I remove Cisco's banner from 2811 router?
banner login ^C
Cisco Router and Security Device Manager (SDM) is installed on this device.
This feature requires the one-time use of the username "cisco"
with the password "cisco". The default username and password have a privilege le
vel of 15.
Please change these publicly known initial credentials using SDM or the IOS CLI.
Here are the Cisco IOS commands.
username <myuser> privilege 15 secret 0 <mypassword>
no username cisco
Replace <myuser> and <mypassword> with the username and password you want to use
For more information about SDM please follow the instructions in the QUICK START
GUIDE for your router or go to http://www.cisco.com/go/sdm
mohammedmahmoud
Level 11
Level 11
Kindly use "no banner login" in the global configuration mode.
HTH,
Mohammed Mahmoud.
mohammedmahmoud
Level 11
Level 11
HTH,
Mohammed Mahmoud.
