How do you ground a 2960x switch?
patrick.lally1
I don't see any screw holes for grounding lugs. There are holes for screws on all the other products I've used from Cisco. Any ideas?
5 Replies 5
Jason Dodge
Same.... there's a clear spot on 3560x, nothing on 2960xr? I'm putting a couple PoE with full power redundant power suppies into a DC plant and required to bond. Not really sure if those designtated spots afford any more protection or are any different from any other part on the device's chasis though....?
Ganesh Hariharan
Hello Patrick,
Are you saying only raw switch been shipped without any screws and mounting kits ??
If that is the case , The either purchase or connect with cisco team with whom purchased was done.
Have a look on the below link for installation and mounting 2960 in various ways.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/hardware/installation/guide/2960_hg/higinstl.html
Hope it Helps..
-GI
So , there's no external attachment point like the rest of your equipment
Reading through your manual it even describes it but I guess this is  just generic copies sent with all equipment ?
Did you every fine your answer ??
Anyone have an answer for this question?
