ANNOUNCEMENT - The community will be down for maintenace this Thursday August 13 from 12:00 AM PT to 02:00 AM PT. As a precaution save your work.
Highlighted
Beginner
How does the MEMS Optical Switch work?
Optical switch, based on MEMS(Micro-Electro-Mechanical System). What is MEMS and how does it work?
Marketing at HYC Co., Ltd, a China manufacturer of fiber connectivity,WDM, PLC splitter and high-density datacom cabling over 19 years.
1 ACCEPTED SOLUTION
Highlighted
Hall of Fame Master
Re: How does the MEMS Optical Switch work?
Hello hycsystembella,
looking at the following page
https://www.diconfiberoptics.com/products/mems_1_x_n_optical_switches_single_mode.php
https://agiltron.com/category/fiber-optic-switches/mems-optical-switches-etmems/
These MEME optical switches are adavanced actually optical splitters able to split the signal of a fiber to multiple fibers or to do the opposite with a different device combining the signal of N input fibers into a single fiber.
These are very specialized devices that have very specific use like duplicating a signal for network monitoring, in one way video distribution.
They do not examine the packets that travel inside the fiber in the modulated optical signal, they can just split or combine optical signals.
Of course the action of splitting can produce N copies of the original signal but with reduced optical power.
For an explanation on their working principles you can read
https://www.researchgate.net/publication/309168203_MEMS_optical_switch_Switching_time_reduction
there is a pdf document there.
Hope to help
Giuseppe
4 REPLIES 4
Highlighted
VIP Mentor
Highlighted
Hall of Fame Master
Hope to help
Giuseppe
Highlighted
Beginner
Thanks for your kindly reply. I also found this blog for more information about MEMS optical switch. http://optical-passive.com/
It is based on MEMS technology to control and switch the optical path.  What about MCS?
Highlighted
Hall of Fame Master
thanks for your kind remarks.
About the MCS optical switches:
they work without using micromirrors like the MEMS do.
According to the following document :
https://www.neophotonics.com/multicast-switch-work-part/
>> The complex crisscrosses between the top-layer splitters and bottom-layer switches indicate the real need for a photonic integrated circuit, i.e., a planar lightwave circuit (PLC) based on a silica-on-silicon chip. MCSs based on PLC are not only more suited for mass production than other technologies such as MEMS, but can also offer the advantage of small and compact size.
The documents also mention that in MCS erbium doped fiber optical amplifiers may be used to improve output power level (to compensate for power loss caused by splitting).
These MCS are actually more complex as they are classified as Optical Add Drop Multiplexer O ADM.
They are able to operate OADM  at optical wavelength level:
>> In Fig.1, the traffic is from or to 8 directions. Any one of the 80-96 wavelengths in a particular direction can be dropped to or added from any one of the 16 output or input ports. How this is achieved can described as follows.
Hope to help
Giuseppe
Content for Community-Ad
