How to change the below default values in STP
chandra_rc16
Level 4
Level 4
How to change the below default values:
Hello Time  2 sec  Max Age 20 sec  Forward Delay 15 sec
             Aging Time  20
I'm not seeing any parameter indicating them in the root bridge.
Switch0(config)#spanning-tree vlan 10 ?
  priority  Set the bridge priority for the spanning tree
  root      Configure switch as root
  <cr>
Thanks in advance
Chandu
Regards, Chandu
Yes PT have limitation about specific commands:
Here is the commands to change:
spanning-tree [vlan stp-list] max-age seconds
Interval the switch waits between receiving BPDUs from the root switch.
Enter a number from 6 to 200.
spanning-tree [vlan stp-list] hello-time seconds
Interval from 1 to 10 seconds.
spanning-tree [vlan stp-list] forward-time seconds
Forward-delay interval from 4 to 200 seconds.
Hope it helps.
Reagrds
The max-age setting must be greater than the hello-time setting.
7 Replies 7
John Blakley
Is this on real equipment? You should have options for forward-time and hello-time after you specify the vlan.... What platform is this?
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
This is a virtual software and is none another than PT.
Chandu
Regards, Chandu
Packet Tracer is still quite limited in what it can do. You could look into using the Cisco Learning Labs.
https://learningnetworkstore.cisco.com/market/prod/listSubCatLearnLab.se.work?TRGT=85&/nxt/rcrs/=2559
Daniel Dib
CCIE #37149
Daniel Dib
CCIE #37149
CCDE #20160011
Please rate helpful posts.
Hope it helps.
Reagrds
chandra_rc16
Level 4
Level 4
So will PT help me to pass CCNA or not ?
Regards, Chandu
Hi chandu,
PT is more then enough for CCNA.
But still if you Cisco devices then u can try with them.
Try some PT simulated question from Internet and try to solve them.
chandra_rc16
Level 4
Level 4
Thanks sandeep.
Regards, Chandu
