em 12-20-2023 07:26 AM
for 3 switches that are logically stacked together?
Solucionado! Ir para a Solução.
em 12-20-2023 07:53 AM
Not much information guide correctly-
what switch model - and what IOs Code running ?
what kind of stacking (physical stack cable or flex stacking )
If you confiured switch priorrity and switch number ( master switch should have all the configuration)
show switch show you forming the stacking, you can also view all the logs when the switches joined in stack.
you can also do testing removing master switch and see all the configuration synched to salve switch (if this pre-stage environment).
em 12-20-2023 07:31 AM
Hello @Iloveyou
Since all switches are "ready" (master and members) #show switch, configuration is sync.
em 12-20-2023 07:34 AM
em 12-20-2023 08:02 AM
Does a show interface show the ports on all 3 switches? If so, you likely have a functional single switch with all the physical switches operational.
em 12-20-2023 01:24 PM
What model and firmware is the stack?
Descubra e salve suas ideias favoritas. Volte para ver respostas de especialistas, passo a passo, tópicos recentes e muito mais.
Novo por aqui? Comece com estas dicas. Como usar a Comunidade Guia do novo membro
