02-18-2011 07:00 PM - edited 03-06-2019 03:38 PM
Hi all,
i have 3550SMIA switch and needs to know if i plug cisco phone then it gets power from the switch.
how can i find that my switch supports Poe??
3550SMIA# sh ver
Cisco IOS Software, C3550 Software (C3550-IPSERVICESK9-M), Version 12.2(44)SE6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 09-Mar-09 20:28 by gereddy
Image text-base: 0x00003000, data-base: 0x012A99FC
ROM: Bootstrap program is C3550 boot loader
3550SMIA uptime is 11 weeks, 6 days, 1 hour, 48 minutes
System restarted at 18:08:32 MST Sat Nov 27 2010
System image file is "flash:c3550-ipservicesk9-mz.122-44.SE6.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco WS-C3550-24-PWR (PowerPC) processor (revision D0) with 65526K/8192K bytes of memory.
Processor board ID CAT0722R1DQ
Last reset from warm-reset
Running Layer2/3 Switching Image
Ethernet-controller 1 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 2 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 3 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 4 has 1 Gigabit Ethernet/IEEE 802.3 interface
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
384K bytes of flash-simulated NVRAM.
Base ethernet MAC Address: 00:0D:28:BC:FD:80
Motherboard assembly number: 73-8100-07
Power supply part number: 341-0029-02
Motherboard serial number: CAT072101VJ
Power supply serial number: DTH07220Y3N
Model revision number: D0
Motherboard revision number: A0
Model number: WS-C3550-24PWR-SMI
System serial number: CAT0722R1DQ
Configuration register is 0x10F
thanks
mahesh
Solved! Go to Solution.
02-18-2011 07:09 PM
Hi Mahesh,
Your switch can support up to 15.4 (Class 3). Make sure you enable CDP. Plug the phone and do this command again. You'll see it'll tell you what phone model it is.
02-18-2011 07:02 PM
Supports PoE or PoE capable..
What do you get when you run the command "sh power inline"?
02-18-2011 07:06 PM
Hi ,
Here is info
3550SMIA#sh power inline
Available:360(w) Used:0(w) Remaining:360(w)
Interface Admin Oper Power Device Class Max
(Watts)
Fa0/1 auto off 0.0 n/a n/a 15.4
Fa0/2 auto off 0.0 n/a n/a 15.4
Fa0/3 auto off 0.0 n/a n/a 15.4
Fa0/4 auto off 0.0 n/a n/a 15.4
Fa0/5 auto off 0.0 n/a n/a 15.4
Fa0/6 auto off 0.0 n/a n/a 15.4
Fa0/7 auto off 0.0 n/a n/a 15.4
Fa0/8 auto off 0.0 n/a n/a 15.4
Fa0/9 auto off 0.0 n/a n/a 15.4
Fa0/10 auto off 0.0 n/a n/a 15.4
Fa0/11 auto off 0.0 n/a n/a 15.4
Fa0/12 auto off 0.0 n/a n/a 15.4
Fa0/13 auto off 0.0 n/a n/a 15.4
Fa0/14 auto off 0.0 n/a n/a 15.4
Fa0/15 auto off 0.0 n/a n/a 15.4
Fa0/16 auto off 0.0 n/a n/a 15.4
Fa0/17 auto off 0.0 n/a n/a 15.4
Fa0/18 auto off 0.0 n/a n/a 15.4
Fa0/19 auto off 0.0 n/a n/a 15.4
(Watts)
Fa0/20 auto off 0.0 n/a n/a 15.4
Fa0/21 auto off 0.0 n/a n/a 15.4
Fa0/22 auto off 0.0 n/a n/a 15.4
Fa0/23 auto off 0.0 n/a n/a 15.4
Fa0/24 auto off 0.0 n/a n/a 15.4
thanks
mahesh
02-18-2011 07:09 PM
Hi Mahesh,
02-18-2011 07:13 PM
Hi Leolaohoo,
Many thanks for reply.
regards
mahesh
02-18-2011 07:14 PM
Thanks for the ratings Mahesh.
