03-22-2011 09:41 AM - edited 03-06-2019 04:12 PM
hello,
1)
is it possible to connect a CISCO 2960 with a CISCO 3560 with the Cisco Catalyst 3560 SFP Interconnect Cable ?
or must i use the copper GB port (below the SFP module slot) on the 2960 and a GLC-T SFP module in the 3560 and connect them with a CATx cable?
2)
is it possible to connect a 3560 and a 3750 with the Cisco Catalyst 3560 SFP Interconnect Cable?
thanks!
03-22-2011 11:48 AM
I can only answer question two, relating to the connection of a 3560 and a 3750 with the Cisco Catalyst 3560 SFP Interconnect Cable. The answer in my experience is no - it will not work.
Regards, S.
03-25-2011 12:18 PM
I believe SFP Interconnect Cable is for 3560 series switches only.
